Thanks for the answers. I’m gonna try at this weekend!
Von: David Winslow [mailto:dwinslow@anonymised.com]
Gesendet am: Freitag, 23. Mai 2008 15:21
An: Andrea Aime
Cc: Ziegler Stefan; geoserver-users; Justin Deoliveira
Betreff: Re: [Geoserver-users] GeoServer and Google’s Geo Search
The GeoSearch module is not included in (pre-)releases; it is still a
community module. You can build it pretty easily, however. All that is
needed is to check out the most recent version of GeoServer trunk (and I
do mean most recent, the last couple of commits have improved things
greatly) and run "mvn install -Prest,geosearch’
This will produce web/target/geoserver.war which can be deployed
normally; you should probably back up your data dir just to be on the
safe side.
GeoServer by itself will provide the GeoSearch index under
http://localhost:8080/geoserver/rest/sitemap.xml (follow links therein
to see the output describe individual layers).
Additionally, if you set up a recent checkout of GeoWebCache and create
a layer with the format set to ‘geosearch-kml’ then you can point Google
Earth at
http://localhost:8080/geowebcache/service/kml/.geosearch-kml.kml
to see automatically regionated data. This requires going to the
GeoServer configuration page and specifying the attribute to use;
GeoServer will then ensure that features with higher values of this
attribute show up when Google Earth is at world-scale zoom levels and
those with lower values show up as you zoom in.
Feel free to bother me with any questions or problems; thanks a lot for
the interest!
-David
Andrea Aime wrote:
Ziegler Stefan ha scritto:
Hi
I read the blog entry about Geoserver and Google’s Geo Search and I’m
fascinated. Can I grab the 1.7 alpha version and play around or do I
need a trunk version?You do need a trunk version as well as a community module… not
sure how the build is done for it, maybe a profile… I’ll let
Justin/David chime in and provide more detailsCheers
Andrea!DSPAM:4040,4836b84c120871628642973!
