[Geoserver-users] geoserver as windows service and administration
Hi, I have recently install geoserver in windows 2003 server. When I run it in console mode it works fine. I wanted to install it as a windows service with “geoserver_service_wrapper”. It seems to work but now I can’t connect to the administration page “http://localhost:8080/geoserver”. and I have this error message: HTTP ERROR: 404 NOT_FOUND RequestURI=/geoserver Powered by jetty:// My config is : Window 2003 Server with IIS 6. If someone see what is wrong… Thanks.
View this message in context: geoserver as windows service and administration
I found the response in this forum. I had to create a system environnement
variable "GEOSERVER_DATA_DIR" with the value of the path of data_dir for
geoserver.
JBR34 wrote:
windows service with "geoserver_service_wrapper".
It seems to work but now I can't connect to the administration page
"http://localhost:8080/geoserver"\.
HTTP ERROR: 404
NOT_FOUND
Powered by jetty://
If someone see what is wrong...
Thanks.
View this message in context: http://www.nabble.com/geoserver-as-windows-service-and-administration-tf3876724.html#a11005142
