[Geoserver-users] Geoserver clustering
Hello,
I want to set up geoserver clustering, but the documentation is a bit brief - https://docs.geoserver.org/latest/en/user/production/misc.html#set-up-clustering
The idea is 2 Linux servers, sharing the data folder by NFS. I’ve found out for now.
  • The secondary can’t be read-only
  • Log file path should be moved outside the data folder, or they overwrite each others logs
  • General – Catalog settings has a file locking setting. Are there more?
  • GWC settings – locking should be NIO
  • GCW storage – Internal H2 db can’t be used by 2 processes so must have real database.
  • Netcdf – Must also use a centralized DB
Am I missing something? Has anyone more experience or docs about clustering geoserver?
Hans Yperman
Department IT
IT staff
Vlaams Instituut voor de Zee vzw
InnovOcean site, Wandelaarkaai 7
8400 Oostende, België
T +32 (0) / M +32 (0)
www.vliz.be
You might want to read this too: https://docs.geoserver.geo-solutions.it/edu/en/clustering/index.html
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
