I have been compiling latest Geoserver successfully many times.
Recently I encountered this error message:
[ERROR] Failed to execute goal
org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile
(default-compile) on project main: Compilation failure
[ERROR] \Geoserver\src\main\src\main\java\org\geoserver\ows\kvp\CQLFilterKvpParser.java:[26,8]
cannot access ParseException
[ERROR] class file for ParseException not found
[ERROR] try {
Thanks for helping.
Quan
On Mon, Sep 5, 2011 at 7:10 PM, quan huynh <quanchuynh@anonymised.com> wrote:
I have been compiling latest Geoserver successfully many times\.
[ERROR] try {
Thanks for helping\.
No idea. GeoServer depends on Geotools snapshots buidls, I've observed
in the past
that sometimes old snapshots get downloaded from the repositories.
Core developers do not notice since they are also geotools developers,
so we have
both checkouts and jars built fresh from the sources each day.
Maybe checking out the corresponding geotools branch and building it
will fix your problem
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
