Hello list,
I must be overlooking something simple. I am using the REST API to create a Geoserver coveragestore and coverage. I followed the example and successfully created the store. However, when I go to the web interface I find that I didn’t publish/create the image mosaic jdbc store.
This is the code snippet that I am using in python
payload = f.read()
headers = {‘Content-type’:‘text/xml’}
resp = requests.post(workspace_url, auth=(user,word), data=payload, headers=headers)
I tried posting to an xml to this url “/workspaces//coveragestores//coverages/” and received a 401 error.
I am overlooking something, but I am not sure what. According to this url (http://docs.geoserver.org/stable/en/user/rest/api/coveragestores.html). The coverage should be created automatically. " The coverageName parameter specifies the name of the coverage within the coverage store. This parameter is only relevant if the configure parameter is not equal to “none”. If not specified the resulting coverage will receive the same name as its containing coverage store. "
However, I do not have a new layer in geoserver. It is possible for me to go through the web interface and add the layer, but I would prefer to automate if possible.
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
612-626-3933
www.terrapop.org
"/workspaces/<ws>/coveragestores/<cs>/coverages/<c>" and received a 401
error.
Can you say what you are really posting? What are <ws>, <cs> and <c> here?
Also, can you confirm that that isn't the full URL (i.e. you really did put a
machine name and protocol to the URL)?
What is the data type you are trying to upload?
What user are you trying to upload as?
Brad
Hi Brad,
Hope this helps clear things up
workspacename = GLI_CEREAL
coveragestore = BARLEYHAR
coverage = BARLEYHAR
I successfully created a image mosaic jdb coveragestore by posting an xml at url1url1: http://geoserver.terrapop.org/geoserver/rest/workspaces/GLI_CEREAL/coveragestores/
This resulted in a successful coveragestore at the following address, url2. However, no coverage/layer was automatically published from this coveragestore. So I am looking for an example of creating the coverage from the coveragestore I believe.
url2: http://geoserver.terrapop.org/geoserver/rest/workspaces/GLI_CEREAL/coveragestores/BARLEYHAR
Also, I tried posting a coverage.xml to this new url and received a 403 error
http://geoserver.terrapop.org/geoserver/rest/workspaces/GLI_CEREAL/coveragestores/BARLEYHAR/coverages
error.
Can you say what you are really posting? What are , and here?
Also, can you confirm that that isn’t the full URL (i.e. you really did put a
Brad
Geoserver-users mailing list
David Haynes, Ph.D.
612-626-3933
www.terrapop.org
Please provide all the information requested. Its easier to help you if you
help us...
Brad
I found a solution. It had to do with the data being uploaded not the url.
error.
Brad
David Haynes, Ph.D.
612-626-3933
www.terrapop.org
