[Geoserver-users] Geoserver dxf
I have just started working with the DXF OutputFormat for WFS.
The extension works well and reasonably fast, but I wonder if there is a
plan to add the text output type in the dxf file.
Support for Oracle oriented geometries would be also awesome.
Thanks in advance.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-dxf-tp5214782.html
Hi, thanks for feedbacks on the dfx extension.
Unfortunately there is no plan for new features on the extension, basically because there is no funding for it.
If you wish these improvements, your options are:
  • code the new functionality by yourself (we can help if you have problems doing that) and submit a pull request
  • contact one of the companies offering commercial support for GeoServer and ask them to develop the new functionalities (see here: http://geoserver.org/support/)
  • wait and hope until someone else will develop / fund these new features
Mauro Bartolomeoli
2015-07-08 8:29 GMT+02:00 xmiquel <xmiquel@anonymised.com>:
Thanks in advance.
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
On Wed, Jul 8, 2015 at 8:29 AM, xmiquel <xmiquel@anonymised.com> wrote:
I cannot say I'm aware of anyone working on further extensions to the DXF
output format, but one never knows what the next round of code
donations/projects/contracts
might bring in, you might get lucky and get what you want.
If someone interested can develop in Java, the DXF output format is not
actually that complicated:
https://github.com/geoserver/geoserver/tree/master/src/extension/dxf/core/src/main/java/org/geoserver/wfs/response
See also the contribution guidelines:
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
In case of urgent need you can also check out one of the commercial support
providers:
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
