[Geoserver-users] geoserver fails to start w/ tomcat 6 and fedora 6
Hello,
I have played withe geoserver 1.6.0-RC1 & have run it with tomcat 5.5 and
6.0.14 under Windows XP.
Can't seem to get it running using fedora 6. I have modified the startup.sh
script, have the geoserver_data_dir defined. Here is the catalina.out from
the logs directory:
------------------------------------ START of log output
Jan 8, 2008 5:47:18 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path:
/usr/local/jdk1.6.0_02/jre/lib/i386/client:/usr/local/jdk1.6.0_02/jre/lib/i386:/usr/local/jdk1.6.0_02/jre/../lib/i386:/usr/java/packages/lib/i386:/lib:/usr/lib
Jan 8, 2008 5:47:18 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-9080
Jan 8, 2008 5:47:18 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 4818 ms
Jan 8, 2008 5:47:19 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Jan 8, 2008 5:47:19 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.14
08 Jan 17:47:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: /usr/local/data_dir
08 Jan 17:47:31 ERROR [context.ContextLoader] - Context initialization
failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'config' defined in URL
[jar:file:/usr/local/apache-tomcat-geo-6.0.14/webapps/geoserver/WEB-INF/lib/main-1.6.0-RC1.jar!/applicationContext.xml]:
Initialization of bean failed; nested exception is
java.lang.NullPointerException: null
  at java.io.FileInputStream.<init>(FileInputStream.java:103)
  at
org.vfny.geoserver.global.xml.XMLConfigReader.loadServices(XMLConfigReader.java:248)
  at
org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:209)
  at
org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:171)
  at org.vfny.geoserver.global.Config.setApplicationContext(Config.java:90)
  at
org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:84)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:248)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:362)
  at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
  at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
  at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:312)
  at
  at
  at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:275)
  at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:318)
  at
org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
  at
org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
  at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
  at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
  at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3830)
  at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4337)
  at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
  at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
  at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:525)
  at
org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:920)
  at
org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:883)
  at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:492)
  at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1138)
  at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
  at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:117)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
  at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
  at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
  at org.apache.catalina.core.StandardService.start(StandardService.java:516)
  at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
  at org.apache.catalina.startup.Catalina.start(Catalina.java:566)
  at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
  at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
  at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
  at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Jan 8, 2008 5:47:31 PM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/geoserver] startup failed due to previous errors
Jan 8, 2008 5:47:32 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-9080
Jan 8, 2008 5:47:32 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:9009
Jan 8, 2008 5:47:32 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/41 config=null
Jan 8, 2008 5:47:32 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 13479 ms
------------------------------------ END of log output
Does this look like something someone has solved?
Thanks a bunch!
-B
View this message in context: http://www.nabble.com/geoserver-fails-to-start-w--tomcat-6-and-fedora-6-tp14703885p14703885.html
This happens when the GEOSERVER_DATA_DIR is not set up properly. I
notice your data dir is pointing at /usr/local/data_dir. What is the
conents of that directory? It should look something like:
/usr/local/data_dir/
    catalog.xml
    services.xml
    featureTypes/
-Justin
bruciebruce wrote:
Hello,
the logs directory:
failed
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
  at
Thanks a bunch!
-B
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
