not sure this is the right place to ask for GeoFence but let me try.
So I’m running multiple geserver in cluster: all having a separate replica of the data+datadir but connected to the same database via a connection pool configured in tomcat (one Database for each cluster).
The loadbalancer is rotating through the Geoserver and the session is not shared for the moment.
I’ve several of clusters like these and all are meant to be used as read only, update is performed rolling/updating the snapshot of the disks (automatically by the cloud manager with no downtime).
The clusters have an external Master Geoserver (one for each cluster) used as model for the snapshots, so ANY write operation will be performed over those instances and the cluster will be lazily updated later (pull).
Now I’m starting looking at GeoFence to manage the authentications and to grant permissions over layers for any write operation over Master instances (multiple customers) and for any read operation over the clusters…
In our scenario users can be managed across different cluster so I’ve to centralize the user management (federated identity provider) and possibly permissions.
Few initial questions about geofence:
To simplify the infrastructure I’m wondering if it is possible to install it as embedded plugin server sharing the GeoFenceDataSource configuration over a single postgis DB (shared across one or more clusters and the relatives Masters instances)?
Is GeoFence able to limit access to the Geoserver’s REST api to grant permissions to create resources via REST (f.e. w/ GeoCatBridge) this is something that I’m currently doing with rest.properties but I’d like to make it configurable via GUI.
is geofence really multitenant: supporting mutiple domains and paths (not just by workspace)
If it’s not possible to share the database, how to clusterize an embedded/standalone geofence server?
looking here I see it’s possible to point to a database with an internal jdbc connection pool, is it possible to use an external (defined in tomcat) jdbc connection pool configuring geofence datasource via jndi? (any example is really appreciated)
Thank you so much for any hint to address this new challenge.
C.
Mr. Carlo Cancellieri
skype: ccancellieri
Twitter: @cancellieric
LinkedIn: http://it.linkedin.com/in/ccancellieri/
Dear List,
maybe it was to complex, let me simplify:
How I can administer security/rest.properties via UI?
F.e.: Is GeoFence able to limit access to the Geoserver’s REST api, granting permissions to create resources (workspaces,stores,layers) via REST ?
How did you manage that dynamically (at runtime)?
C.
skype: ccancellieri
Ciao Carlo,
please, read below…
Dear List,
No, GeoFence is for OGC Services.
I think you simply cannot at the moment.
C.
C.
skype: ccancellieri
skype: ccancellieri
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
