I would like to integrate geonetwork into my existing install of
GeoServer but was unable to find any docs on how to do this. Do I
just deploy the geonetwork war in my webapps? How do I sync the data?
Any help or pointers would be great.
To my knowledge there is no automatic integration. This is what I did:
Deployed GeoServer and GeoNetwork as separate webapps (.war files).
See http://geonetwork-opensource.org how to setup GeoNetwork.
After both GeoServer and GeoNetwork have been setup you can harvest metadata from GeoServer by configuring standard GeoNetwork OGC WMS/WFS Harvesters through the GeoNetwork admin webpages. For more GeoNetwork assistence consult https://lists.sourceforge.net/lists/listinfo/geonetwork-users
If you need a more integrated "out-of-the-box" solution you may want to check out GeoNode: http://geonode.org which includes both GS and GN.
best,
Just van den Broecke
www.justobjects.nl
Any help or pointers would be great.------------------------------------------------------------------------------
Lotusphere 2011
Register now for Lotusphere 2011 and learn how
to connect the dots, take your collaborative environment
to the next level, and enter the era of Social Business.
http://p.sf.net/sfu/lotusphere-d2d
Geoserver-users mailing list
Hi
This document can help to setup GeoNetwork in tomcat:
http://geonetwork-opensource.org/_static/foss4g2010/FOSS4G_Mastering_Advanced_GeoNetwork.pdf
Jose García
On Wed, Dec 15, 2010 at 5:38 PM, Just van den Broecke <just@anonymised.com> wrote:
See http://geonetwork-opensource.org how to setup GeoNetwork.After both GeoServer and GeoNetwork have been setup you can harvest
assistence consult
https://lists.sourceforge.net/lists/listinfo/geonetwork-usersIf you need a more integrated “out-of-the-box” solution you may want to
check out GeoNode: http://geonode.org which includes both GS and GN.best,
Lotusphere 2011
Lotusphere 2011
