[Geoserver-users] GeoServer & GeoNetwork integration
Hi List,
Does anyone have any good information about GeoServer and GeoNetwork integration? We have a GeoServer deployment that’s working fine and are now interested in integrating GeoNetwork with it.
I found this 4 year old document - http://geoserver.org/display/GEOS/GeoServer+GeoNetwork+Integration - which makes it sound like it’d be nice and integrated, and there’s an interesting slide-show from GeoSolutions (http://www.slideshare.net/geosolutions/geoserver-geonetwork-and-inspire-where-we-are-and-what-is-missing) but that just gives generalities rather than practical suggestions.
So has anyone done this? We’d prefer a pretty tight integration if possible. Is there any documentation for how to get them to work together nicely?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
