[Geoserver-users] Geoserver GeoTIFF Image Composition
I have hit my head in a wall trying to figure out an issue in geoserver.
I have published a Geotiff (3 bands RGB EPSG: 4326). This geotiff has a white border (R=255,G=255, B=255). After publishing in geoserver, the layer translates N and rotates NE. It seems that this RGB white border which has an (X,Y) information is causing the image move.
Does anyone has experienced this problem and could share a solution?
Thank you for your time in advance.
Julierme Pinheiro
Hi Julierme,
do you have any chance to share the output of the “gdalinfo” command being run on that file?
Which GeoServer version are you using?
Daniele
On Mon, Jan 29, 2018 at 2:33 PM, Julierme Pinheiro <juliermeopensourcedeveloper@anonymised.com> wrote:
Julierme Pinheiro
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com.382…sourceforge.net
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Hi Julierme,
please, keep the discussion on the GeoServer users mailing list so any other user/dev can provide additional assistance or feedbacks on the topic if available.
In reference to “translate to N and rotate NE”, are you doing any reprojection on the WMS getMap call?
How did you set the SRS handling in your layer configuration?
In case the problem still exist, you can open a JIRA with a minimal set of samples and a few instructions on how to configure the layer, in order to replicate the issue.
Daniele
On Mon, Jan 29, 2018 at 7:56 PM, Julierme Pinheiro <juliermeopensourcedeveloper@anonymised.com> wrote:
Dear Daniele,
I am attaching a file showing both images:
1 - the top image is a geoserver wms/wmts (with translation and rotation)
2 - the bottom image is in a file system directory.
Best Regards
Julierme
2018-01-29 11:59 GMT-02:00 Daniele Romagnoli <daniele.romagnoli@anonymised.comsolutions.it>:
Hi Julierme,
Daniele
On Mon, Jan 29, 2018 at 2:33 PM, Julierme Pinheiro <juliermeopensourcedeveloper@anonymised.commail.com> wrote:
Julierme Pinheiro
Geoserver-users@anonymised.comrge.net
Daniele Romagnoli
Daniele Romagnoli
