[Geoserver-users] Geoserver giving pink tiles after getting to work with pgbouncer
I have a geoserver map that is using a postgres database to get all the data
to draw the map.
I then had to install pgbouncer to get it allow more people to be abe to use
it. When I did not use pgbouncer I could only get one person to browse the
map.
I managed to get geoserver to read pgbouncer instead of getting it to read
postgres directly but now I seem to be getting pink tiles. On occasion it
would be the whole map and other times it would be just parts of the map.
Can anyone please help any ideas on how I solve this problem now?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-giving-pink-tiles-after-getting-to-work-with-pgbouncer-tp5088168.html
Ciao,
please, read my comments inline below...
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
to draw the map.
map.
I don't understand what do you mean here. Only one person?
Can you be more specific? This statemet looks a bit strange to me :slight_smile:
It is hard to tell. Generally speaking we would need to know more
about what you are doing?
- geoserver version
- pg versione
- which container
- which os
- some info on the data
That said, you can raise the logging level in GeoServer and inspect
which queries are failing and why. You can also resend them via
pgadmin or psql in order
to check if it is GeoServer or PG that is failing to respond.
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
I think the most common reason to get pink is, that one or more layers do not load properly. The reason may be different projection or some other trouble with the layer. I just had this pink problem with my javascript-based app, and noticed that one of the WMS-layers were actually missing due to wrong configuration.
Oiva Hakala, Agrifood Research Finland
________________________________________
Lähettäjä: Simone Giannecchini [simone.giannecchini@anonymised.com]
Lähetetty: 9. marraskuuta 2013 12:24
Vastaanottaja: Ravyn
Kopio: geoserver-users
Aihe: Re: [Geoserver-users] Geoserver giving pink tiles after getting to work with pgbouncer
Ciao,
Simone Giannecchini
more information.
@simogeo
Founder/Director
to draw the map.
map.
- geoserver version
- pg versione
- which container
- which os
