Dear Jonathan,
a few things in random order:
-1- 1G permsize? Do you really need it?
-2- 64MB is not the memory that GeoServer will use for a single
request (the total one I mean). It imposes a limit on the backbuffer
on which geoserver will render, hence it is an indirect limitation to
the size of the image one can request (#bands*w*h tells you the size
of the backbuffer in bytes)
This means that depending on the underlying data as well as on the
style it can use much more memory.
Aside, memory is not released instantaneously hence under load unless
you put control flow in the mix you might still get OOM errros
-3- put XMX == XMS there is no point on a server application to set
them differently it will simply make it easier to fragment heap memory
and make OOM easier ti happen.
There is more but this is just a braing dumpo of obvious things.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Mar 8, 2016 at 1:48 PM, Jonathan Moules
<jonathan-lists@anonymised.com> wrote:
So I doubled the XMX to 12G and sure enough it can now handle 8 threads with
no problems.
But curiously, I then restarted the instance again (to throw in a second
instance) but the very first request returned:
Rendering process failed
java.lang.OutOfMemoryError: Java heap space
Java heap space
I've seen this during a few of my tests - the first request (sometimes first
several) somehow comes back as being memory constrained, even though there
are/should be no demands on GeoServer when it's received.
Is this normal?
Jonathan
---- On Tue, 08 Mar 2016 11:31:43 +0000 <jonathan-lists@anonymised.com> wrote
Hi List,
I'm experiencing some memory issues with GeoServer 2.7.1 on Linux. The
startup settings are:
jvm_opts=-Xms2G -Xmx6G -XX:MaxPermSize=1024m (So 6GB of Heap).
I'm running some JMeter tests to make requests like this:
http://localhost:8080/geoserver/wms?LAYERS=myayer&FORMAT=image%2Fpng8&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A27700&BBOX=404453,555869,415688,572175&WIDTH=3210&HEIGHT=4659&FORMAT_OPTIONS=dpi:300
As you can see, it's for a very large image: 3210 * 4659 at 300DPI (A3
printing size; alas we cannot use tiles). While mostly targetted at rural
areas there are some towns in the given areas, so well into the 10's of
thousands of features sometimes hundreds of thousands. The data is coming
from Oracle.
WMS "Max rendering memory (KB)" is at 64MB (the default); I've increased
rendering time to be up to 5 mins (the max is taking about 100 seconds).
Using 5 threads in Jmeter against one instance and running tests against
lots of different scales we're seeing a probably 10-20% of requests return:
<ServiceException code="internalError">
Java heap space
</ServiceException>
We've also had at least one of these:
java.lang.OutOfMemoryError: GC overhead limit exceeded
</ServiceException>
Given there are only 5 threads, and the max rendering memory is a mere 64MB,
even taking into account all the features that need to be loaded, we're
surprised that somehow Java is running out of space. Is it worth increasing
the -Xmx even higher? Is there anything else we can do to obviate this
problem?
Jonathan
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://makebettercode.com/inteldaal-eval
Geoserver-users mailing list
