[Geoserver-users] Geoserver ignoring socketTimeout setting in MapFish
I have set my
**socketTimeout**
setting very high in my config.yaml file (Mapfish).
Tiles that return within 30 seconds from geoserver to mapfish works 100%. Problem comes in with very large raster tiles (that takes more than 30 seconds). In this case mapfish reports a Timed out error and the PDF is empty. It seems that geoserver ignores the socketTimeout setting in the Mapfish config.yaml file.
I am using the latest Geoserver (2.15.2) and Mapfish extension (geoserver-2.15.2-printing-plugin.zip).
Regards
Schalk
I think this file is only read by mapfish (not by geoserver).
Have you set connectionTimeout too? I think socketTimeout defaults to 180 seconds (180000), but connectionTimeout defaults to 30 seconds (which you mention below), so maybe that is the limiting condition here.
Brad
Sent: Monday, 8 July 2019 12:04 PM
Subject: [Geoserver-users] Geoserver ignoring socketTimeout setting in MapFish
I have set my
**socketTimeout**
Regards
Schalk
Hi Brad,
I have already tried setting both socketTimeout and connectionTimeout. Believe me, it is not that, but defnitely sockectTimeout ignored, because, like I said tiles that returns before 30 secods is getting treated by mapfish, otherwise it give timed out error. Since 2016 there was this problem. See:
https://sourceforge.net/p/geoserver/mailman/message/35025291/
Brad
I have set my
**socketTimeout**
Regards
Schalk
I have set my
**socketTimeout**
Regards
Schalk
I have set my
**socketTimeout**
Regards
Schalk
Hi Schalk,
I had a look at the mapfish code, and unfortunately it looks that the version included in GeoServer print plugin (print-lib 2.1.4) ignores the timeouts in config.yaml.
They are now set in spring application context files.
You can find the one used by the geoserver plugin in the gs-printing jar (the file named applicationContext.xml). This means that those settings are currently hard-coded unless you extract and change that file in the jar.
Look for this section:
Mauro
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Mauro,
Wow,
Thanks for the fast feedback. I am not that familiar with extracting jar, modifying results and then putting it back into the jar. I only have basic Linux knowledge. Is it possible you can guide me in the right direction?
Best Regards
Schalk
On 09 Jul 2019 13:34, Mauro Bartolomeoli wrote:
Hi Schalk,
Mauro
Il giorno mar 9 lug 2019 alle ore 12:23 Schalk Grobbelaar <schalk@anonymised.com> ha scritto:
I have set my
**socketTimeout**
Regards
Schalk
I have set my
**socketTimeout**
Regards
Schalk
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Mauro Bartolomeoli
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Dott. Mauro Bartolomeoli @mauro_bart Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy
mobile: +39 393 904 1756 phone: +39 0584 962313 fax: +39 0584 1660272 http://www.geo-solutions.it http://twitter.com/geosolutions_it -------------------------------------------------------
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
A jar is really just a zip file with a different extension. So you can edit files by just opening them with your
favouite zip tool, change the contents of the file, and the restart GeoServer to have the changes take effect
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thanks Andrea,
Much appreciated.
Regards
Schalk
On Tue, Jul 9, 2019 at 1:47 PM Schalk Grobbelaar <schalk@anonymised.com> wrote:
Hi Mauro,
Wow,
Best Regards
Schalk
Hi Schalk,
Mauro
I have set my
**socketTimeout**
Regards
Schalk
I have set my
**socketTimeout**
Regards
Schalk
Mauro Bartolomeoli
