[Geoserver-users] Geoserver Install
Hi, a problem with geoserver...
I have had it running in vista and all was well. I also had running pgAdmin
(i.e. using postgis) but had to reinstall it. After the re-install of
pgAdmin, GeoServer will no longer run on http://localhost:8080/geoserver . I
can start it as administrator and it runs but i get a error 404 page not
found.
Afer searching around I found you could change the port GeoServer runs on so
I did. The good news is that an additional line is added to the console when
starting GeoServer but I still get the 404 error in the browser after
changing the address to the new port. I have tried a number of ports (8070,
1979) but still no answer.
I have to say I am quite new this stuff, any ideas for a fix??
Thanks
View this message in context: http://www.nabble.com/Geoserver-Install-tp21621757p21621757.html
Could you include the console log on startup. My guess is that some error is occurring to prevent geoserver from starting up. With the log we can better diagnose what that is.
-Justin
found.
Thanks
Justin Deoliveira
OpenGeo - http://opengeo.org
Thanks, the log is below.
I notice the bind error close to the bottom so I have tried to change the
port but to no use...
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean
(AbstractBeanFactory.java:164)
        at
org.springframework.beans.factory.support.BeanDefinitionValueResolver
.resolveReference(BeanDefinitionValueResolver.java:269)
        at
.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
        at
org.springframework.beans.factory.support.ConstructorResolver.resolve
ConstructorArguments(ConstructorResolver.java:495)
        at
org.springframework.beans.factory.support.ConstructorResolver.autowir
eConstructor(ConstructorResolver.java:162)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBean
Factory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
        at
Factory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
        at
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
        at
Factory$1.run(AbstractAutowireCapableBeanFactory.java:409)
        at java.security.AccessController.doPrivileged(Native Method)
        at
Factory.createBean(AbstractAutowireCapableBeanFactory.java:380)
        at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getOb
ject(AbstractBeanFactory.java:264)
        at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistr
y.getSingleton(DefaultSingletonBeanRegistry.java:221)
        at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBe
an(AbstractBeanFactory.java:261)
        at
(AbstractBeanFactory.java:185)
        at
        at
org.springframework.beans.factory.support.DefaultListableBeanFactory.
preInstantiateSingletons(DefaultListableBeanFactory.java:429)
        at
org.springframework.context.support.AbstractApplicationContext.finish
BeanFactoryInitialization(AbstractApplicationContext.java:729)
        at
org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:381)
        at
org.springframework.web.context.ContextLoader.createWebApplicationCon
text(ContextLoader.java:255)
        at
org.springframework.web.context.ContextLoader.initWebApplicationConte
xt(ContextLoader.java:199)
        at
org.springframework.web.context.ContextLoaderListener.contextInitiali
zed(ContextLoaderListener.java:45)
        at
org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.
java:540)
        at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
        at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
a:1220)
        at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
510)
        at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448
        at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
39)
        at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
.java:152)
        at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
dlerCollection.java:156)
        at
39)
        at
.java:152)
        at
39)
        at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
130)
        at org.mortbay.jetty.Server.doStart(Server.java:222)
        at
39)
        at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
        at org.mortbay.start.Main.invokeMain(Main.java:183)
        at org.mortbay.start.Main.start(Main.java:497)
        at org.mortbay.start.Main.main(Main.java:115)
4563 [main] WARN org.mortbay.log - failed
org.mortbay.jetty.NCSARequestLog@anonymised.com
e7
java.io.FileNotFoundException: C:\Program Files\GeoServer
1.7.2\logs\2009_01_27.
request.log (Access is denied)
        at java.io.FileOutputStream.openAppend(Native Method)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:177)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
        at
org.mortbay.util.RolloverFileOutputStream.setFile(RolloverFileOutputS
tream.java:243)
        at
org.mortbay.util.RolloverFileOutputStream.<init>(RolloverFileOutputSt
ream.java:164)
        at org.mortbay.jetty.NCSARequestLog.doStart(NCSARequestLog.java:378)
        at
39)
        at
org.mortbay.jetty.handler.RequestLogHandler.doStart(RequestLogHandler
.java:117)
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
4595 [main] WARN org.mortbay.log - failed RequestLogHandler@anonymised.com
        at
tream.java:243)
        at
ream.java:164)
        at
39)
        at
.java:117)
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
4628 [main] WARN org.mortbay.log - failed HandlerCollection@anonymised.com
        at
tream.java:243)
        at
ream.java:164)
        at
39)
        at
.java:117)
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
4662 [main] WARN org.mortbay.log - Error starting handlers
        at
tream.java:243)
        at
ream.java:164)
        at
39)
        at
.java:117)
        at
39)
        at
.java:152)
        at
39)
        at
130)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
4730 [main] WARN org.mortbay.log - failed
SelectChannelConnector@anonymised.com:8080
java.net.BindException: Address already in use: bind
        at sun.nio.ch.Net.bind(Native Method)
        at
sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:
119)
        at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:59)
        at
org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChannelConnec
tor.java:205)
        at
org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelCon
nector.java:304)
        at
39)
        at org.mortbay.jetty.Server.doStart(Server.java:233)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
4755 [main] WARN org.mortbay.log - failed Server@anonymised.com
        at
119)
        at
tor.java:205)
        at
nector.java:304)
        at
39)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
4775 [main] WARN org.mortbay.log - EXCEPTION
        at
119)
        at
tor.java:205)
        at
nector.java:304)
        at
39)
        at
39)
        at
java:39)
        at
sorImpl.java:25)
Thanks again
Justin Deoliveira-6 wrote:
-Justin
pgAdmin
. I
found.
so
when
(8070,
Thanks
Justin Deoliveira
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Geoserver-Install-tp21621757p21681922.html
If the error is still this one, either you changed the port in the
wrong place, or you changed it to another busy port?
I also see this one thought:
Apparently your used does not have permissions to write to
the following folder:
C:\Program Files\GeoServer1.7.2\logs\
GeoServer needs write permissions under all subdirectories
of the program install one (C:\Program Files\GeoServer1.7.2).
Maybe uninstall, and then install it in your home folder?
Andrea Aime
Thanks!!! Chnaged the directory to home and he presto. Also had to change to
port but now all up and running.
Thanks again.
the
Andrea Aime
View this message in context: http://www.nabble.com/Geoserver-Install-tp21621757p21743830.html
