I downloaded 2.15.1, unzipped and run startup.bat with Eclipse Adoptium\jdk-11.0.13.8-hotspot\ and Geoserver started for me as usual.
I am not sure what is the best method for changing the Jetty port but editing the star.ini file did not work for me. By adding -Djetty.http.port=8090 into the java options in startup.bat made Geoserver to start on port 8090.
-Jukka Rahkonen-
Lähettäjä: Russ <russ@…4690…>
Lähetetty: maanantai 10. tammikuuta 2022 21.24
Vastaanottaja: Jibran Khan <jk.envs@…84…>
Kopio: GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Geoserver is not starting while running startup batch script
I might be wrong but I think Java 11 needs a liter. version of GeoServer.
Why do you need the old version?
On 10 Jan 2022, at 19:10, Jibran Khan <jk.envs@…84…> wrote:
Hello,
I am trying to run an older version of Geoserver (Ver 2.15.1) on my Windows 10 (64 bit) PC. The script startup.bat starts and crashes. I have tried running the script with Admin privileges, changing port in start.ini (e.g. jetty.port = 8989) and reload, opening port in Windows firewall, nothing seems to work.
I also checked Windows services, but couldn’t find Geoserver as a service there.
Java_Home: set to JDK 11
GEOSERVER data dir points to data directory of Geoserver
Can someone give me some hints to fix this?
Here is the crash log via Windows CMD console:
:INFO:oejsh.ContextHandler:main: Started o.e.j.w.WebAppContext@…11286…{GeoServer,/geoserver,file:///C:/path_to/GeoServer%202.15.1/webapps/geoserver/,AVAILABLE}{C:\path_to\GeoServer 2.15.1\webapps\geoserver}
:WARN:oejx.XmlConfiguration:main:
java.security.PrivilegedActionException: java.net.BindException: Address already in use: bind
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1511)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:220)
at org.eclipse.jetty.start.Main.start(Main.java:486)
at org.eclipse.jetty.start.Main.main(Main.java:77)
Caused by:
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Unknown Source)
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:339)
at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:307)
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80)
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:235)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.server.Server.doStart(Server.java:395)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1572)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1512)
java.lang.reflect.InvocationTargetException
Caused by: java.security.PrivilegedActionException: java.net.BindException: Address already in use: bind
… 7 more
Caused by: java.net.BindException: Address already in use: bind
… 9 more
… 7 more
… 9 more
Usage: java -jar $JETTY_HOME/start.jar [options] [properties] [configs]
java -jar $JETTY_HOME/start.jar --help # for more information
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Thanks a lot for your responses. I fixed it! The address was indeed in use, and for some strange reason, I couldn’t change the port by making several attempts in start.ini (jetty.port). It didn’t work for me.
So, I took a backup of the data directory, upgraded to Geoserver 2.21.0 at a different port, reloaded, and Voila! All seems to be ok
Cheers!
Jibran
On Tue, 11 Jan 2022 at 17:32, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Lähettäjä: Russ <russ@anonymised.com>
Vastaanottaja: Jibran Khan <jk.envs@anonymised.com>
Kopio: GeoServer Mailing List List <geoserver-users@anonymised.comorge.net>
On 10 Jan 2022, at 19:10, Jibran Khan <jk.envs@anonymised.com> wrote:
Hello,
:INFO:oejsh.ContextHandler:main: Started o.e.j.w.WebAppContext@anonymised.com{GeoServer,/geoserver,file:///C:/path_to/GeoServer%202.15.1/webapps/geoserver/,AVAILABLE}{C:\path_to\GeoServer 2.15.1\webapps\geoserver}
Caused by:
… 7 more
… 9 more
… 7 more
… 9 more
