[Geoserver-users] Geoserver performance tips
Hi Guys,
I a relatively new to Geoserver and i was hoping someone can direct me to where i can find tips to improve/speed up my Geoserver?. I have notice that my maps are relatively slow to load and i was hoping to find some tips.
Nome
Hi Nomeneta,
I would recommend you to start from here
http://docs.geoserver.org/2.3.3/user/production/index.html
Regards
Michele
On Tue, Jul 9, 2013 at 2:45 PM, Nomeneta Saili <nome.saili@anonymised.com> wrote:
Hi Guys,
Nome
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Nome,
Try this page:
http://docs.geoserver.org/stable/en/user/production/index.html?highlight=production
Also - TMS (or WMTS or tiled WMS-C) is much better for a basemap than WMS.
Jonathan
On 9 July 2013 13:45, Nomeneta Saili <nome.saili@anonymised.com> wrote:
Hi Guys,
Nome
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
