[Geoserver-users] Geoserver Poi Template:Displaying pictures
Hello Everyone
I am seeking advise regarding displaying pictures in the popup.
I did create a popup and also changed the template as per this tutorial,
http://docs.geoserver.org/latest/en/user/tutorials/GetFeatureInfo/index.html
My challenge is I cannot find this directory being refered to here in Geoserver
workspaces/topp/DS_poi/poi
I am assuming it is this directory on my computer,
C:\Program Files (x86)\GeoServer 2.12.1\data_dir\workspaces\topp\states_shapefile\states
under this directory there are five files
description.ftl
featuretype.xml
layer.xml
title.ftl
I am hoping it is the featuretype.xml file being referred to in the tutorial? my question, where do I paste the code being referred to in this tutorial in the xml file? Can I display my pictures straight from the attribute table or I need to do some other settings.
Kindly advise, your assistance will be highly appreciated.
Regards
Amelia
The pictures I would like to display are stored in an attribute table.
This pictures have
On Fri, Apr 6, 2018 at 1:52 AM, Nauwanga Nauwanga <amellynicodemus@anonymised.com> wrote:
Hello list,
I wanted to say I did manage to get rid of the X Frame error
Here is the solution,
https://helpx.adobe.com/target/kb/how-to-use-a-browser-extension-to-remove-x-frame-options-console.html
Thank you Dave for the hints,
On Tue, Apr 3, 2018 at 2:34 PM, Dave Potts <mrdapotts@anonymised.com> wrote:
Cors issues normally need to be resolved by your web server.
There is a cors filter that needs to be enabled in the current version of tomcat.
https://tomcat.apache.org/tomcat-8.0-doc/config/filter.html
There is also a plugin in for Chrome that will spoof the cors issue
https://chrome.google.com/webstore/detail/allow-control-allow-origi/nlfbmbojpeacfghkpbjhddihlkkiljbi?hl=en
In Spring is possible to turn a filter on.
see
On 3 April 2018 at 09:19, Nauwanga Nauwanga <amellynicodemus@anonymised.com> wrote:
If there is anyone who can assist with setting proxy for Openlayer 4, I will really appreciate.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.comrge.net
On Tue, Apr 3, 2018 at 9:55 AM, Nauwanga Nauwanga <amellynicodemus@anonymised.com> wrote:
Hi Andria,
Yes I am still busy researching, I believe I have found the solution which has to do with cross domain. I therefore need to set my proxy accordingly.
I am getting the error that says access to image has been blocked by CORS policy.
The real issue is now how to set proxy in Openlayer 4.
I have found some links with the setting but not working?
Here are some links with the solution
http://www.fernandoquadro.com.br/html/2009/03/05/configurando-o-proxyhost-no-openlayers/
https://khayer.wordpress.com/2010/07/14/open-layer-with-geosever/
Still busy trying to get this figured and working.
Kind regards
Amelia
On Thu, Mar 29, 2018 at 11:07 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
HI Amelia,
I see you got no answer here, maybe you should ask on the OpenLayers mailing list too?
On Wed, Mar 28, 2018 at 4:33 AM, Nauwanga Nauwanga <amellynicodemus@anonymised.com> wrote:
Hello Everyone
I am new to Web Mapping and I have been trying to get the feature info to work for my WMS when I group them with Openlayer. I am using Openlayer 4.
I am trying the following to no success
http://openlayers.org/en/latest/examples/getfeatureinfo-tile.html
Thank you for your kind help.
Kind regards
Amelia
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On 16 April 2018 at 17:06, Nauwanga Nauwanga <amellynicodemus@anonymised.com>
wrote:
Hello Everyone
Tutorials — GeoServer 2.26.x User Manual
Geoserver
That is a reference to the layer with the points of interest in the example
- you should replace that with the <workspace> name of your data (for topp)
and the name of your <DataStore> for DS_poi and the name of your <feature
type> for poi
description.ftl
featuretype.xml
layer.xml
title.ftl
Never, ever (even in fun) change the featuretype.xml file it will break
GeoServer's ability to display your data. You should be editing the
content.ftl file
Ian
Hello Ian,
Thank you for yesterday’s recommendation I tried to work on it to no success.
Please advise where I am going wrong,
Also would like to mention that the pictures are stored in QGIS (hyperlinks) and would like the same to show below the list of attribute in openlayers (is this possible?).
Thank you for your help.
content.ftl (632 Bytes)
On Mon, Apr 16, 2018 at 6:33 PM, Ian Turton <ijturton@anonymised.com> wrote:
On 16 April 2018 at 17:06, Nauwanga Nauwanga <amellynicodemus@anonymised.com> wrote:
Hello Everyone
That is a reference to the layer with the points of interest in the example - you should replace that with the name of your data (for topp) and the name of your for DS_poi and the name of your for poi
Never, ever (even in fun) change the featuretype.xml file it will break GeoServer’s ability to display your data. You should be editing the content.ftl file
Ian
description.ftl
featuretype.xml
layer.xml
title.ftl
