[Geoserver-users] geoserver preview GWC layers WMTS to localhost:8080
Dear all,
I recently updated from 2.6.2 tot 2.13.2.
Jetty is running on 8080 and the IIS is the default web server. There are rewrite rules in the IIS which translate :80/geoserver to :8080/geoserver.
Geoserver works mostly okay with Global setting - Proxy base url: the external IIS address (domain:80/geoserver); previewing gwc layers makes the OL viewer attempt to open “localhost:8080”.
Is there somewhere a setting to avoid this?
Many thanks!
Francis Vanden Bulcke
Technisch Applicatiespecialist GIS
Projecten, Ontwikkeling en Nazorg
Domein GPS (Grond- en Persoonsgebonden Systemen)
Digipolis
Bellevue 1, 9050 Gent
Tel.: +32 (0)92660972
http://www.digipolis.gent
Disclaimer
This is a known bug (https://osgeo-org.atlassian.net/browse/GEOS-7653) which was fixed at the FOSS4G code sprint (https://github.com/geoserver/geoserver/pull/3079). Currently this fix is only available on the nightly master builds but will be part of 2.14.0 when it is released.
If this is a critical bug for your company please consider sponsoring a back port to the old release branches.
Ian
Ian Turton
Hi Ian, Miranda,
Thanks a lot for the usefull info.
We will install 2.14.0 as it is released from 24/09.
Francis
Verzonden: vrijdag 21 september 2018 16:13
Ian
On Fri, 21 Sep 2018 at 15:04, Vanden Bulcke Francis <Francis.VandenBulcke@…7339…> wrote:
Dear all,
Many thanks!
Digipolis
Disclaimer
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
