[Geoserver-users] Geoserver Production Environment specs
What would typically be virtual server specs in terms of RAM and processor speed you would recommend for production environment to serve several applications?
of Layers served totally from this server ~200 - 250
of Layers simultaneously accessed in an application ~10
Data format(vectors only): PostGIS Layers and few shapefiles(max size of each 60MB).
of simultaneous users : Max 5-10.
Also, does one typically serve all the layers from the a BIG server instance or multiple small server instances with small configuration?
I know that this is a very open ended question. Any rough estimate is appreciated.
Ravi.
Hi Ravi,
It really depends on what you expect the load to be on the server. For instance if you only expect the server to be accessed by a handful of users then some pretty modest requirements will probably work. For smaller installations that don’t typically handle much load we typically use a vm with 1-2 G of RAM giving about half of it to geoserver. For larger setups obviously the requirement goes up.
It also matters what type of traffic you will be doing. For instance if you are strictly doing WMS then the more memory the better since for rendering the WMS has to continually allocate large chunks of memory for images. Whereas WFS operates in a strictly streaming fashion.
There is currently an issue as well in that if you have that many layers/feature types you will want to change the “feature type cache settings” (global settings page) to be larger than the number of layers/feature types.
Also it is important to properly configure the server in terms of limits. You should find this article interesting:
http://opengeo.org/publications/geoserver-production/
Hope that helps.
-Justin
On Wed, Jan 5, 2011 at 11:02 AM, Ravi Pavuluri <ravitheja@anonymised.com> wrote:
Ravi.
Learn how Oracle Real Application Clusters (RAC) One Node allows customers
to consolidate database storage, standardize their database environment, and,
should the need arise, upgrade to a full multi-node Oracle RAC database
without downtime or disruption
http://p.sf.net/sfu/oracle-sfdevnl
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Thank you for the information. I read the link you sent and it was a very good one.
I am looking at both WMS(50%) and WFS(50%) in each application in a tomcat environment with maximum simultaneous users about 5-10.“For smaller installations that don’t typically handle much load we typically use a vm with 1-2 G of RAM giving about half of it to geoserver.” Is this the case you are referring when you have geoserver as a webapp in Tomcat? Tomcat and Geoserver both being java based, consume more RAM and you would still suggest 2GB of RAM with server optimizations? With the above configurations, is 5-6GB RAM with decent processor considered a safe estimate or an overestimate?
Ravi,
To: Ravi Pavuluri ravitheja@anonymised.com
Sent: Thu, January 6, 2011 11:07:49 AM
Subject: Re: [Geoserver-users] Geoserver Production Environment specs
Hi Ravi,
Hope that helps.
-Justin
Ravi.
Justin Deoliveira
Hi Ravi,
On Thu, Jan 6, 2011 at 5:52 PM, Ravi Pavuluri <ravitheja@anonymised.com142…> wrote:
Hi Justin,
Yes, i am referring to geoserver running in tomcat or some other servlet container. Memory is allocated to the servlet container.
Yes, but again it depends. The more memory you allocate the more requests you can handle which improves overall availability of your app. So in the end its a trade off and you have to find the balance.
In most production systems I see that do a lot of traffic I usually don’t see more than 4G allocated to java/tomcat/geoserver. And even that is a bit excessive. With heap sizes that large you start to pay a big price for garbage collection.
I would say with your requirements allocating 2G of ram to java should be more than enough if the server is “properly configured”. By properly configured I mean both the services (using control flow, wms limits, etc…) and the data (spatial indexes, attribute indexes based on your SLD styles, etc…)
Ravi,
From: Justin Deoliveira <jdeolive@anonymised.com671…>
To: Ravi Pavuluri <ravitheja@anonymised.com>
Cc: geoserver-users@anonymised.comurceforge.net
Hi Ravi,
Hope that helps.
-Justin
Ravi.
Justin Deoliveira
Justin Deoliveira
On Fri, Jan 7, 2011 at 1:52 AM, Ravi Pavuluri <ravitheja@anonymised.com…3142…> wrote:
Hi Justin,
During FOSS4G 2010 WMS shootout, with a single server having 8GB of memory, GeoServer was allocated 2GB of memory with tops 64 concurrent users.
Giving it less or more resulted in measurable slowdowns (this includes both GeoServer and Tomcat, as they are running inside the same JVM).
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Andrea and Justin,
Thank you for sharing your experiences on production environment. I think Andrea’s information would provide an high upper limit for my case and Justin’s information would be a good estimate to start with.
Thanks again,
Ravi.
Cc: Justin Deoliveira jdeolive@anonymised.com; geoserver-users@lists.sourceforge.net
Sent: Fri, January 7, 2011 2:40:52 AM
On Fri, Jan 7, 2011 at 1:52 AM, Ravi Pavuluri <ravitheja@anonymised.com> wrote:
Hi Justin,
Ing. Andrea Aime
fax: +39 0584962313
