I've noticed that sending a HTTP POST request to /workspaces with a valid request body document leads GeoServer to return a response that mixes a content-type of 'application/json' but a response body that is not valid JSON (i.e., the text string with the workspace name as specified in the response body).
This behavior causes problems in some cases. For example, some clients use the Content-Type to pick how to handle the response body, which includes parsing the response body with a JSON parser.
I've tested this with GeoServer 2.15.0.
Best regards,
Rui Maciel
it’s probably some Spring MVC automatism doing that, picking a suitable content type from the default ones, as the code
is returning a response that is plain text without indicating the desired content type for it.
Here is the specific example, but I believe all other “POST” responses in the REST API are in the same situation:
https://github.com/geoserver/geoserver/blob/5424f5bf6384869a7e629d775230a4d4bb3cbb75/src/restconfig/src/main/java/org/geoserver/rest/catalog/WorkspaceController.java#L146
I’d open a bug report first, and then as usual, pull request with a fix and tests are more than welcomed:
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
See also: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-fixes,-improvements-and-new-features-in-GeoServer
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
