[Geoserver-users] Geoserver REST layer security
Hello,
Is it possible to add a user to geoserver and secure some layers with REST?
I’ve found this URL (http://geoserver.org/display/GEOS/User+Collaboration+REST+API) but this seems not work in geoserver 2.1.2.
Met vriendelijke groet,
Lucas Heezen
Beschrijving: http://www.covadis.nl/emailkop/logo.gif
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
e: heezen@anonymised.com
On Thu, Nov 10, 2011 at 9:35 AM, Lucas Heezen - Covadis <heezen@anonymised.com..4103…> wrote:
Hello,
Not that I know of.
That was a R&D page describing a module that never got implemented
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Ok, is there any development on this part or is there some other solution to get this working ?
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
Van: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] Namens Andrea Aime
Verzonden: donderdag 10 november 2011 10:20
Aan: Lucas Heezen - Covadis
CC: geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] Geoserver REST layer security
On Thu, Nov 10, 2011 at 9:35 AM, Lucas Heezen - Covadis <heezen@anonymised.com> wrote:
Hello,
Not that I know of.
Ing. Andrea Aime
Tech lead
Hi, there are 2 developers working hard on a new security subsystem (Justin and me) and the REST API is on the TODO list. Unfortunately, you cannot expect these features in the near future. Surely not in 2.1.x series.
As a workaround, I would do the following.
Look at GEOSERVER_DATA_DIR/security. There are three java property files:
user.properties, layer.properties and service.properties.
The structure is quite simple. You can generate these 3 files instead of making
REST requests. Stop geoserver, copy these files in the location mentioned above, restart geoserver, finish.
Christian
Lucas Heezen
[Beschrijving: http://www.covadis.nl/emailkop/logo.gif\]
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
e: heezen@anonymised.com<mailto:heezen@anonymised.com>
On Thu, Nov 10, 2011 at 9:35 AM, Lucas Heezen - Covadis <heezen@anonymised.com<mailto:heezen@anonymised.com>> wrote:
Hello,
Not that I know of.
I've found this URL (http://geoserver.org/display/GEOS/User+Collaboration+REST+API) but this seems not work in geoserver 2.1.2.
Ing. Andrea Aime
Tech lead
This message was sent using IMP, the Internet Messaging Program.
Then we are going to do that. Can these files be edited real time of do we need to restart geoserver after modification?
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
-----Oorspronkelijk bericht-----
Van: christian.mueller@anonymised.com [mailto:christian.mueller@anonymised.com]
Verzonden: donderdag 10 november 2011 13:43
CC: Andrea Aime; geoserver-users@lists.sourceforge.net
The structure is quite simple. You can generate these 3 files instead of making REST requests. Stop geoserver, copy these files in the location mentioned above, restart geoserver, finish.
Christian
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
Andrea Aime
Hello,
Not that I know of.
I've found this URL
Ing. Andrea Aime
Tech lead
As far as I can remember there is a file watcher, if one of these files changes, it will be reloaded. But you have to try to be sure.
Another hint: if you modify one of these files the changes may have no effect on already authenticated users.
Christian
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
Christian
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
Andrea Aime
Hello,
Not that I know of.
I've found this URL
Ing. Andrea Aime
Tech lead
On Thu, Nov 10, 2011 at 1:42 PM, <christian.mueller@anonymised.com..1968…> wrote:
Afaik the current security subsystem watches the file contents for modifications, so the restart should
not be needed
Ing. Andrea Aime
Tech lead
