By what reference the version is optional? I had a look at the “Styled Layer Descriptor profile of the Web Map Service Implementation Specification” and there, in Table 9 —GetLegendGraphic operation request URL parameters the WMS version is defined to be mandatory.
GetLegendGraphics works when version is included:
http://beta.geoportal.ypen.gr/geoserver/aqd-wms/ows?service=WMS&request=GetLegendGraphic&format=image%2Fpng&width=20&height=20&layer=AM.AirQualityManagementZone&version=1.3.0
-Jukka Rahkonen-
Lähettäjä: Elena Grigoriou <grigoriouelena@…84…>
Lähetetty: maanantai 4. huhtikuuta 2022 11.10
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] Geoserver returns an exception as a response to a GetLegendGraphic request
I am using Geoserver 2.20.2.
I have configured various wms. An example is the following:
http://beta.geoportal.ypen.gr/geoserver/aqd-wms/ows?service=wms&version=1.3.0&request=GetCapabilities
In the capabilities document, I find the GetLegendGraphic request, which seems well formed based on the standard.
The version parameter is missing but it is not mandatory. I think that Geoserver is supposed to respond using the default version.
Unfortunately, when I send the request, I get the following ows exception.
ows:ExceptionTextCould not determine version</ows:ExceptionText>
Has anyone experienced the same behaviour?
Is it some configuration issue that I am missing?
Thanks in advance.
Indeed the version parameter is mandatory!
So it seems that geoserver does not form the request according to the standard.
Let’s see if there is a workaround or any configuration steps to overcome this issue…
On Mon, 4 Apr 2022 at 11:35, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Lähettäjä: Elena Grigoriou <grigoriouelena@anonymised.com>
Thanks in advance.
See this ticket, fixed beginning of 2022: https://osgeo-org.atlassian.net/browse/GEOS-10336
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
