[Geoserver-users] geoserver/saml/metadata endpoint
Hello -
Normally when developing Spring SAML SP’s, Spring creates an endpoint that outputs the SP’s metadata XML under <context_root>/saml/metadata. I have configured the SAMLv2 filter but when I attempt to hit geoserver/saml/metadata, I receive a 404. Is the SAML filter not programmed to expose the saml/metadata endpoint?
thank you,
Alessandro
Hello -
Just wondering if anyone has any insight into this?
Thank you
Signed,
Alessandro Ferrucci
Alessandro,
the module is a “community module”, which among other things, means there is no appointed maintainer.
Looking at the short module history, there are only two commits that are actually relevant to the modules
(the other two are general housekeeping), and they are from two italian developers… and it’s August :smiley:
For this module, I believe your choices are either to delve into its code yourself, or look for a commercial
support provider that can help. If enough business starts rolling around the module, there are good chances
it might become an officially supported module down the road.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Thank you very much for the reply, Andrea. SAML integration is a fairly integration requirement for the successful adoption of GeoServer in our enterprise, so I will happily delve into the source code to better understand it. I’ve done SAML work with Spring Security in the past with various projects, so I’d be happy to dig into this module.
Alessandro
On Wed, Aug 25, 2021, 9:23 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Alessandro,
On Wed, Aug 25, 2021 at 3:10 PM Alessandro Ferrucci <alessandroferrucci@anonymised.com> wrote:
Hello -
Thank you
On Mon, Aug 23, 2021 at 10:24 PM Alessandro Ferrucci <alessandroferrucci@anonymised.com> wrote:
Hello -
thank you,
Alessandro
Signed,
Alessandro Ferrucci
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
