[Geoserver-users] Geoserver Store NetCDF issue: Could not find layers
Hello,
After browsing around this forum, seems like this is a common issue, but I
still do not seem to find a solution.
I am attempting to upload NetCDF files onto geoserver via netCDF extension.
Using sample .nc from the web, this extension works.
However, when I attempt to upload my own files, I encounter the error "Could
not find layer".
I understand that geoserver requires CF/COARDS convention, I have attempted
to rename my dimensions to be in accordance to this. Are there still other
aspects of the .nc that I have to alter? Are there alternative methods (ie,
converting to other file formats?) I've tried converting to geoTiff and .shp
via GDAL but have no success in that.
Attached: my .nc file (dispersion2.nc), geoserver log
https://www.dropbox.com/sh/m5gebm21z73ng1y/AADky3C3q2mga0WqsyJ57Pbka?dl=0
Thanks & Bless,
Matt
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Store-NetCDF-issue-Could-not-find-layers-tp5244318.html
Hi Matt,
I was able to check your sample.
It seems like a problem on your dataset OR on the underlying UCAR NetCDF java lib.
Let me try to explain that in order to figure out the real issue.
When GeoTools/GeoServer accesses a NetCDF file, it delegates the UCAR NetCDF lib (currently, 4.6.0 version) to open a NetCDF dataset. Due to the wide amount of conventions, types, structures existing in the NetCDF world, the UCAR lib tries to individuate the convention used by the specific sample, by parsing some attributes, datatypes or elements.
For your case, the lib thinks that your data is part of the M3IOConvention.
https://github.com/Unidata/thredds/blob/master/cdm/src/main/java/ucar/nc2/dataset/conv/M3IOConvention.java#L72
since during the preliminar scan it finds the set of attributes required by that convention.
// global attributes:
:NCOLS = 921; // int
:NROWS = 301; // int
:XORIG = -144.5; // double
:YORIG = 40.0; // double
:XCELL = 0.10000000149011612; // double
:YCELL = 0.10000000149011612; // double
Afterwards, it tries to setup the coordinates based on that convention:
https://github.com/Unidata/thredds/blob/master/cdm/src/main/java/ucar/nc2/dataset/conv/M3IOConvention.java#L98
And here is where it throws a NPE exception since the expected field doesn’t actually exists.
At this point, I have a set of questions for you.
How did you create this file? Can you share some more information about that? Is it somehow related with the M3IOConvention?
I’m asking this so you can fix your sample data in case it isn’t well formed OR we can keep in touch with the UCAR team to improve their library to support this sample in case it is a properly formed dataset.
Please, let me know.
Best Regards,
Daniele
On Fri, Jan 8, 2016 at 5:40 PM, brownbagel <fungyuensang_mf@anonymised.com> wrote:
Hello,
However, when I attempt to upload my own files, I encounter the error “Could
not find layer”.
converting to other file formats?) I’ve tried converting to geoTiff and .shp
Thanks & Bless,
Matt
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Hello Daniele,
Thanks for the reply, not an expert on this but I will answer to the best of my abilities.
The netCDF files are an output of a fire smoke dispersion model called bluesky in which are initialized by .ARL files from National Weather Service containing met info of our domain.
The .ARL file’s coordinate system is Polar stereographic projection which seems to be related to the M3IO convention. As well, the M3IO api mentions this convention is a standard for air quality models (EPA), perhaps this is related to the dispersion model I am using.
As well, in a vain attempt to make the netCDF convention fit into COARDS, the .nc file named ‘dispersion2’ has it’s dimension names editted. Dispersion_original.nc is the untainted output file from the bluesky framework.
Matt
Hi Matt, I was able to check your sample. It seems like a problem on > your dataset OR on the underlying UCAR NetCDF java lib. Let me try to > explain that in order to figure out the real issue. > > When GeoTools/GeoServer accesses a NetCDF file, it delegates the UCAR > NetCDF lib (currently, 4.6.0 version) to open a NetCDF dataset. Due > to the wide amount of conventions, types, structures existing in the > NetCDF world, the UCAR lib tries to individuate the convention used > by the specific sample, by parsing some attributes, datatypes or > elements. > > For your case, the lib thinks that your data is part of the > M3IOConvention. > https://github.com/Unidata/thredds/blob/master/cdm/src/main/java/ucar/nc2/dataset/conv/M3IOConvention.java#L72 > > >
// global attributes: :NCOLS = 921; // int :NROWS = 301; // int > :XORIG = -144.5; // double :YORIG = 40.0; // double :XCELL = > 0.10000000149011612; // double :YCELL = 0.10000000149011612; // > double > > Afterwards, it tries to setup the coordinates based on that > convention: > https://github.com/Unidata/thredds/blob/master/cdm/src/main/java/ucar/nc2/dataset/conv/M3IOConvention.java#L98 > > >
At this point, I have a set of questions for you. How did you create > this file? Can you share some more information about that? Is it > somehow related with the M3IOConvention? I’m asking this so you can > fix your sample data in case it isn’t well formed OR we can keep in > touch with the UCAR team to improve their library to support this > sample in case it is a properly formed dataset. > > Please, let me know. Best Regards, Daniele > > > > On Fri, Jan 8, 2016 at 5:40 PM, brownbagel <[hidden email] > </user/SendEmail.jtp?type=node&node=5245897&i=0>> wrote: > > Hello, > > After browsing around this forum, seems like this is a common issue, > but I still do not seem to find a solution. > > I am attempting to upload NetCDF files onto geoserver via netCDF > extension. Using sample .nc from the web, this extension works. > However, when I attempt to upload my own files, I encounter the error > “Could not find layer”. > > I understand that geoserver requires CF/COARDS convention, I have > attempted to rename my dimensions to be in accordance to this. Are > there still other aspects of the .nc that I have to alter? Are there > alternative methods (ie, converting to other file formats?) I’ve > tried converting to geoTiff and .shp via GDAL but have no success in > that. > > Attached: my .nc file (dispersion2.nc http://dispersion2.nc), > geoserver log > https://www.dropbox.com/sh/m5gebm21z73ng1y/AADky3C3q2mga0WqsyJ57Pbka?dl=0 > > >
Thanks & Bless,
Hi Matt,
I have checked the second NetCDF file you provided.
Although this one will be properly opened by the UCAR lib (note: this is the low-level one), GeoServer and GeoTools won’t be available to open that (these high level libs can only deal with CF datasets), due to the lack of proper dimensions and properly specified Coordinates.
See these sections of the convention for further details:
http://cfconventions.org/cf-conventions/v1.6.0/cf-conventions.html#grid-mappings-and-projections
http://cfconventions.org/cf-conventions/v1.6.0/cf-conventions.html#appendix-grid-mappings
As well as the main GeoServer NetCDF documentation pages.
http://docs.geoserver.org/latest/en/user/extensions/netcdf/netcdf.html#notes-on-supported-netcdfs
http://docs.geoserver.org/latest/en/user/extensions/netcdf/netcdf.html#supporting-custom-netcdf-coordinate-reference-systems
Hope this helps.
Daniele
On Mon, Jan 18, 2016 at 5:24 PM, Matthew Fung <fungyuensang_mf@anonymised.com95…> wrote:
Hello Daniele,
Matt
Thanks & Bless,
Matt > > > > > – View this message in context: > http://osgeo-org.1560.x6.nabble.com/Geoserver-Store-NetCDF-issue-Could-not-find-layers-tp5244318.html > >
Geoserver-users mailing list [hidden email] > </user/SendEmail.jtp?type=node&node=5245897&i=1> > https://lists.sourceforge.net/lists/listinfo/geoserver-users > > > > > – == GeoServer Professional Services from the experts! Visit > http://goo.gl/it488V for more information. == > > Ing. Daniele Romagnoli Senior Software Engineer > > GeoSolutions S.A.S. Via Poggio alle Viti 1187 55054 Massarosa (LU) > Italy phone: +39 0584 962313 fax: +39 0584 1660272 > > http://www.geo-solutions.it http://twitter.com/geosolutions_it > > ------------------------------------------------------- > > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003 > > Le informazioni contenute in questo messaggio di posta elettronica > e/o nel/i file/s allegato/i sono da considerarsi strettamente > riservate. Il loro utilizzo è consentito esclusivamente al > destinatario del messaggio, per le finalità indicate nel messaggio > stesso. Qualora riceviate questo messaggio senza esserne il > destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail > e di procedere alla distruzione del messaggio stesso, cancellandolo > dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche > in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo > per finalità diverse, costituisce comportamento contrario ai principi > dettati dal D.Lgs. 196/2003. > > > > The information in this message and/or attachments, is intended > solely for the attention and use of the named addressee(s) and may be > confidential or proprietary in nature or covered by the provisions of > privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New > Data Protection Code).Any use not in accord with its purpose, any > disclosure, reproduction, copying, distribution, or either > dissemination, either whole or partial, is strictly forbidden except > previous formal approval of the named addressee(s). If you are not > the intended recipient, please contact immediately the sender by > telephone, fax or e-mail and delete the information in this message > that has been received in error. The sender does not give any > warranty or accept liability as the content, accuracy or completeness > of sent messages and accepts no responsibility for changes made > after they were sent or for other risks which arise as a result of > e-mail transmission, viruses, etc. > > > > ------------------------------------------------------------------------------ > >
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month > Monitor end-to-end web transactions and take corrective actions now > Troubleshoot faster and improve end-user experience. Signup Now! > http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140 > _______________________________________________ Geoserver-users > mailing list [hidden email] > </user/SendEmail.jtp?type=node&node=5245897&i=2> > https://lists.sourceforge.net/lists/listinfo/geoserver-users > > > ------------------------- If you reply to this email, your message > will be added to the discussion below: > http://osgeo-org.1560.x6.nabble.com/Geoserver-Store-NetCDF-issue-Could-not-find-layers-tp5244318p5245897.html > >
To unsubscribe from Geoserver Store NetCDF issue: Could not find layers, click here < > NAML > http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html!nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers!nabble%3Aemail.naml-instant_emails!nabble%3Aemail.naml-send_instant_email!nabble%3Aemail.naml
View this message in context: Re: Geoserver Store NetCDF issue: Could not find layers
Okay, thanks for the info Daniele,
I do have the content as a list of hourly pngs, perhaps I can geo-reference them then add them as an ImageMosaic.
Matt
On 2016-01-22 6:46 AM, Daniele Romagnoli wrote:
Hi Matt,
Hope this helps.
Daniele
On Mon, Jan 18, 2016 at 5:24 PM, Matthew Fung <fungyuensang_mf@anonymised.com> wrote:
Hello Daniele,
Matt
Thanks & Bless,
