[Geoserver-users] GeoServer tileSize and SRS for best performance with Leaflet
3 questions in one. Our end goal is serving vector and raster data from GeoServer (GeoWebCash) in Leaflet quickly - in other words we are trying to improve performance.
Tile Size
We are deciding if our workflow should use the tile size of 512 OR 256.
GeoSolutions raster processing tutorial (here) is using 512 but 256 is the GeoServer and Leaflet L.TileLayer default.
Does anyone have insight on this?
Is the recommendation different for vector vs raster data?
Projection Settings
We are also investigating performance impacts of projection settings. Leaflet displays everything in 3857, we are currently storing all our vector data in PG in 4269 and the raster data we have been using the datasets local UTM reference such as 26912. If anyone knows what the best projection or combination is. Or if the native SRS doesn’t matter but we should set the Declared SRS to 3857 so that there is as little translation work for GeoServer when the request is called?
  • 26912 - NAD 83 UTM Zone 12
  • 4269 - NAD 83 - PG Default
  • 3857 - leaflet default
  • 4326 - WGS 83
OWS vs GWC
And lastly we are currently calling the layer through
https://…/ows?&service=WMS&request=GetMap&layers=layer_name&styles=&format=image%2Fpng&transparent=true&version=1.1.1&tiled=true&info_format=text%2Fhtml&identify=false&width=256&height=256&srs=EPSG%3A3857&bbox=…
But according to this post to get the GeoWebCashed version we might need to call it through something more like this:
http://example.com/geoserver/gwc/service/wms
Any advice on this is very much appreciated,
Vera
Dear Vera,
please, read below…
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Mon, Mar 1, 2021 at 10:09 PM Vera Green <vera.green.ca@anonymised.com> wrote:
Tile Size
Mind you the two things are not strictly related.
You can’t ensure that tiles on disk align with tiles on map unless you are serving a TMS from files directly.
Bigger tiles, within reason, when preprocessing raster data means less I/O and smaller disk tiles.
For client applications I tend to prefer 512pix tiles as well especially if you have amny overlays as it reduces the # of calls you make.
I think we recently added 512pix gridset on GeoServer to cope with this scenario.
Projection Settings
Native CRS matters if the data IS in that CRS so that you avoid the reprojection, which in some cases has a significant cost.
So by reprojecting upfront you offset the cost of reprojection to the preprocessing stage.
Obviously this is not always possible (if your data covers the poles, you can’t go to google mercator :)) and it might also introduce some inflexibility in what you can do afterwards with your data.
Generally speaking the more you move to a single preprocessing step, the better for serving at scale with speed.
I mean, think about if your case allows it, you could preprocessing everything into static files to be served with TMS or so and put a CDN in front of it.
This means almost no backend, but this does not work for all use cases. You need to balance the possibility to preprocess as much as possible upfront, especially for raster data and balance that with what you need afterwards when serving.
This applies primarily to the storage format, compression and CRS.
  • 4326 - WGS 83
OWS vs GWC
You can use WMS with GWC Direct Integration and simply make sure your client makes calls aligned to a configure gridset in GeoServer and you get caching for free.
Using the TILED vendor option you can even control when to hit the cache or not.
Vera
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
