Hello,
I’m trying to update a datastore with REST.
How do we do that?
This is what I have so far:
$request = “http://server/geoserver/rest/workspaces/topp/datastores/Localhost_Postgis”;
public function _put($request) {
// Connect with CURL
$this->connect($request);
// Set the post parameter.
curl_setopt($this->ch, CURLOPT_PUT, true);
// Set header to XML
curl_setopt($this->ch, CURLOPT_HTTPHEADER, array(“Content-type: application/xml”));
// Add XML to post
curl_setopt($this->ch, CURLOPT_POSTFIELDS, $this->toXml());
// Execute
$buffer = curl_exec($this->ch);
// Check for errors and process results
$this->result(201, $buffer);
// Disconnect
$this->disconnect();
But I get this error: ‘input contained no data’
Met vriendelijke groet,
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
Van: Jon Britton [mailto:jonbritton3@anonymised.com]
Verzonden: donderdag 16 juni 2011 10:55
Aan: geoserver-users
Onderwerp: [Geoserver-users] GeoServer REST + 52north WPS
I’m using the 52north WPS, which can automatically send process outputs to GeoServer using the REST interface. Unfortunately I’m having trouble with adding a shapefile, shown in the logs below.
What does the error “Could not find appropriate shp file in archive” mean? Any help would be appreciated.
Jon
16 Jun 09:42:20 INFO [catalog.rest] - POST workspace N52
Method failed: HTTP/1.1 201 Created
1208297 [http-8080-1] WARN org.apache.commons.httpclient.HttpMethodBase - Going to buffer response body of large or unknown size. Using getResponseBodyAsStream instead is recommended.
1208356 [http-8080-1] INFO org.apache.commons.httpclient.auth.AuthChallengeProcessor - basic authentication scheme selected
16 Jun 09:42:20 INFO [catalog.rest] - PUT file, mimetype: application/zip
16 Jun 09:42:20 ERROR [geoserver.rest] - Could not find appropriate shp file in archive
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.StoreFileResource.handleFileUpload(StoreFileResource.java:152)
at org.geoserver.catalog.rest.StoreFileResource.doFileUpload(StoreFileResource.java:94)
at org.geoserver.catalog.rest.DataStoreFileResource.handlePut(DataStoreFileResource.java:197)
at org.restlet.Finder.handle(Finder.java:298)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:77)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:521)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:640)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:619)
