[Geoserver-users] Geoserver upgrade
Hi is there any special steps to upgrade from 2.1.3 to 2.2.2 on a windows server. We attempted it last night but could not get geoserver to restart. Plenty of loggs where generated but to be honest they do not mean much to us. In the end we had to role back the server.
Does the data dir contain all that is needed to transfer settings from one geoserver install to another?
Cheers in advance.
Think before you print! Save energy and paper.
Do you really need to print this email?
Derbyshire County Council works to improve the lives of local people by delivering high quality services.
You can find out more about us by visiting 'www.derbyshire.gov.uk'. If you want to work for us go to our job pages on 'www.derbyshire.gov.uk/jobs'. You can register for e-mail alerts, download job packs and apply on-line.
Please Note:
This email is confidential, may be legally privileged and may contain personal views that are not the views of Derbyshire County Council. It is intended solely for the addressee. If this email was sent to you in error please notify us by replying to the email. Once you have done this please delete the email and do not disclose, copy, distribute, or rely on it.
Under the Data Protection Act 1998 and the Freedom of Information Act 2000 the contents of this email may be disclosed.
Derbyshire County Council reserves the right to monitor both sent and received emails.
David,
nononono not everything at once. Not on a production machine. Please do the
following:
install the war file as is, check WMS/WFS/etc. check log files, then stop.
add all the add-ons: database, WPS, raster formats whatever you need, start,
read the log files, check the services, then stop again. I there are
problems repeat it one by one.
Create a database connection to your main database by hand, publish a layer,
check it with 'preview', if everything works delete both, then stop.
*Only as a last step*
Change over to your data directory (web.xml, container var, java var or
system var ).
Did your first attempt actually work on the data directory intended, i.e.
the one you thought it would work on?
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department of Sustainability and Environment
Level13, Marland House, 570 Bourke Street
Melbourne 3000
PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.n6.nabble.com/Geoserver-upgrade-tp5021150p5021335.html
