[Geoserver-users] Geoserver-users Digest, Vol 116, Issue 92
Hello List,
I would like to do a performance test on our GeoServer installment. I want to use jmeter for this scenario.
I have found some info on benchmarking here: http://de.slideshare.net/geosolutions/gs-steroids-sgiannecfoss4g20130103
But the listed files - namely the python script to create randomized http requests - is not available anymore.
So how could i create a pytons script which generates the boundary and resolution for the http requests?
On Tue, Jan 26, 2016 at 2:13 PM, Florian Hoedt <gannebamm@anonymised.com> wrote:
Hello List,
You can go though this teaching material here:
http://geoserver.geo-solutions.it/edu/en/adv_gsconfig/jmeter/jmeter_simple.html
There associated Windows zip file contains the scripts you're referring to:
http://geoserver.geo-solutions.it/downloads/training/windows/standard/Training-2.6.X-32-V6.zip
Hope this helps
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
