[Geoserver-users] geoserver.war deployment under JBoss fails
Hi All-
I'm trying to deploy Geoserver under JBoss, but it's failing and I can't
figure out why...
Geoserver 1.6.1
JBoss AS 4.2.2.GA
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_13-b05-241)
Java HotSpot(TM) Client VM (build 1.5.0_13-121, mixed mode, sharing)
Here's the log dump:
21:52:17,717 INFO [TomcatDeployer] deploy, ctxPath=/geoserver,
warUrl=.../deploy/geoserver.war/
21:52:17,934 ERROR [[/geoserver]] Exception sending context initialized
event to listener instance of class
org.geoserver.GeoserverInitStartupListener
java.lang.NoClassDefFoundError
        at
org.geotools.resources.image.ImageUtilities.<clinit>(ImageUtilities.java:70)
        at
org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:59)
        at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3856)
        at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4361)
        at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:790)
        at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:770)
        at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:553)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at
org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:296)
        at
org.jboss.mx.server.RawDynamicInvoker.invoke(RawDynamicInvoker.java:164)
        at
org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:659)
        at
org.apache.catalina.core.StandardContext.init(StandardContext.java:5312)
        at
        at
        at
        at
        at
        at
org.jboss.web.tomcat.service.TomcatDeployer.performDeployInternal(TomcatDeployer.java:301)
        at
org.jboss.web.tomcat.service.TomcatDeployer.performDeploy(TomcatDeployer.java:104)
        at
org.jboss.web.AbstractWebDeployer.start(AbstractWebDeployer.java:375)
        at org.jboss.web.WebModule.startModule(WebModule.java:83)
        at org.jboss.web.WebModule.startService(WebModule.java:61)
        at
org.jboss.system.ServiceMBeanSupport.jbossInternalStart(ServiceMBeanSupport.java:289)
        at
org.jboss.system.ServiceMBeanSupport.jbossInternalLifecycle(ServiceMBeanSupport.java:245)
        at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
        at
        at
org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:155)
        at org.jboss.mx.server.Invocation.dispatch(Invocation.java:94)
        at org.jboss.mx.server.Invocation.invoke(Invocation.java:86)
        at
org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:264)
        at
        at
org.jboss.system.ServiceController$ServiceProxy.invoke(ServiceController.java:978)
        at $Proxy0.start(Unknown Source)
        at
org.jboss.system.ServiceController.start(ServiceController.java:417)
        at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
        at
        at
        at
        at
        at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:210)
        at $Proxy45.start(Unknown Source)
        at
org.jboss.web.AbstractWebContainer.start(AbstractWebContainer.java:466)
        at sun.reflect.GeneratedMethodAccessor152.invoke(Unknown Source)
        at
        at
        at
org.jboss.mx.interceptor.AbstractInterceptor.invoke(AbstractInterceptor.java:133)
        at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
        at
org.jboss.mx.interceptor.ModelMBeanOperationInterceptor.invoke(ModelMBeanOperationInterceptor.java:142)
        at
org.jboss.mx.interceptor.DynamicInterceptor.invoke(DynamicInterceptor.java:97)
        at
org.jboss.system.InterceptorServiceMBeanSupport.invokeNext(InterceptorServiceMBeanSupport.java:238)
        at
org.jboss.wsf.container.jboss42.DeployerInterceptor.start(DeployerInterceptor.java:87)
        at
org.jboss.deployment.SubDeployerInterceptorSupport$XMBeanInterceptor.start(SubDeployerInterceptorSupport.java:188)
        at
org.jboss.deployment.SubDeployerInterceptor.invoke(SubDeployerInterceptor.java:95)
        at
        at
        at $Proxy46.start(Unknown Source)
        at org.jboss.deployment.MainDeployer.start(MainDeployer.java:1025)
        at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:819)
        at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:782)
        at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
        at
        at
        at
        at
        at
        at
        at $Proxy9.deploy(Unknown Source)
        at
org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URLDeploymentScanner.java:421)
        at
org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDeploymentScanner.java:610)
        at
org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.doScan(AbstractDeploymentScanner.java:263)
        at
org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.loop(AbstractDeploymentScanner.java:274)
        at
org.jboss.deployment.scanner.AbstractDeploymentScanner$ScannerThread.run(AbstractDeploymentScanner.java:225)
21:52:18,023 INFO [[/geoserver]] Loading Spring root WebApplicationContext
21:52:18,805 INFO [STDOUT] 24 Apr 21:52:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: /usr/local/geoserver
21:52:19,777 INFO [STDOUT] 24 Apr 21:52:19 WARN [referencing.factory] -
Axis elements found in a wkt definition, the force longitude first axis
order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
UNIT["degree", 0.017453292519943295], PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y",
NORTH], AUTHORITY["EPSG","54004"]]
21:52:20,387 INFO [STDOUT] 24 Apr 21:52:20 ERROR [context.ContextLoader] -
Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'applicationState' defined in URL
[file:/usr/local/adlib/jboss/server/default/deploy/geoserver.war/WEB-INF/classes/applicationContext.xml]:
Can't resolve reference to bean 'data' while setting property 'constructor
argument'; nested exception is
with name 'data' defined in URL
[jar:file:/usr/local/adlib/jboss/server/default/deploy/geoserver.war/WEB-INF/lib/main-1.6.1.jar!/applicationContext.xml]:
Can't resolve reference to bean 'config' while setting property 'constructor
with name 'config' defined in URL
Initialization of bean failed; nested exception is
java.lang.NoClassDefFoundError: null
        at
org.geotools.coverage.grid.io.AbstractGridCoverage2DReader.<clinit>(AbstractGridCoverage2DReader.java:102)
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:164)
        at
org.geotools.gce.imagepyramid.ImagePyramidFormatFactory.isAvailable(ImagePyramidFormatFactory.java:48)
        at
org.geotools.coverage.grid.io.GridFormatFinder.getAvailableFormats(GridFormatFinder.java:89)
        at
org.geotools.coverage.grid.io.GridFormatFinder.getFormatArray(GridFormatFinder.java:144)
        at
org.vfny.geoserver.util.CoverageStoreUtils.<clinit>(CoverageStoreUtils.java:46)
        at
org.vfny.geoserver.global.xml.XMLConfigReader.loadCoverageDTOFromXML(XMLConfigReader.java:1906)
        at
org.vfny.geoserver.global.xml.XMLConfigReader.loadCoverage(XMLConfigReader.java:1787)
        at
org.vfny.geoserver.global.xml.XMLConfigReader.loadCoverages(XMLConfigReader.java:1740)
        at
org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:383)
        at
org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:215)
        at
org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:177)
        at
org.vfny.geoserver.global.Config.setApplicationContext(Config.java:64)
        at
org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:84)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:248)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:362)
        at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:226)
        at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:147)
        at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:176)
        at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:105)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.resolveConstructorArguments(AbstractAutowireCapableBeanFactory.java:713)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:611)
        at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:329)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:275)
        at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:318)
        at
org.springframework.web.context.support.AbstractRefreshableWebApplicationContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
        at
org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:230)
        at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:156)
        at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:48)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at org.jboss.web.AbstractWebDeployer.s
21:52:20,387 INFO [STDOUT] tart(AbstractWebDeployer.java:375)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
21:52:20,392 ERROR [[/geoserver]] Exception sending context initialized
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
21:52:20,394 ERROR [StandardContext] Error listenerStart
21:52:20,394 ERROR [StandardContext] Context [/geoserver] startup failed due
to previous errors
21:52:20,395 INFO [[/geoserver]] Closing Spring root WebApplicationContext
21:52:20,589 WARN [ServiceController] Problem starting service
jboss.web.deployment:war=geoserver.war,id=-1191394307
org.jboss.deployment.DeploymentException: URL
file:/usr/local/adlib/jboss/server/default/deploy/geoserver.war/ deployment
failed
        at
org.jboss.web.tomcat.service.TomcatDeployer.performDeployInternal(TomcatDeployer.java:379)
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
21:52:20,590 ERROR [MainDeployer] Could not start deployment:
failed
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Jim Blaney
View this message in context: http://www.nabble.com/geoserver.war-deployment-under-JBoss-fails-tp16852872p16852872.html
2008/4/24, Jim Blaney <jimblaney@anonymised.com>:
Hi All-
figure out why...
Geoserver 1.6.1
JBoss AS 4.2.2.GA
Hi Jim,
I run GeoServer 1.6.3 on JBoss 4.2.2. I started from the war, unzipped
it and removed
* from the WEB-INF/lib dir:
    - concurrent*.jar and hsqldb*.jar because they are already included in JBoss
    - postgresql*.jar and postgis*.jar because I already have a
PostGIS datasource opened so I already have them in
jboss/server/default/lib with newer versions
    - jai*.jar because I use the native JAI integrated into the JDK
* the data/dir because I set the GEOSERVER_DATA_DIR var and placed the
data elsewhere.
Then I made a new war...
I couldn't integrate GeoServer cleanly with JBoss:
- Can't redirect GeoServer logs into JBoss logs (both are using log4j)
- Can't use the PostGIS datasource defined in JBoss from GeoServer
- Can't connect GeoServer security to a JBoss defined Security Domain/Realm
Gerald
Jim Blaney ha scritto:
Hi All-
figure out why...
Geoserver 1.6.1
JBoss AS 4.2.2.GA
        at
        at
It seems your JBoss installation is not able to see the JAI class, which
is kind of strange since it's bundled along with the GeoServer jars.
Anyways, also have a look at Gerald's answer, you may also try with removing the JAI jars from GeoServer and fully installing JAI in your
JDK instead (it will be good for performance as well).
Hi All-
figure out why...
Geoserver 1.6.1
JBoss AS 4.2.2.GA
Hi Jim,
it and removed
Beware, doing so you may incur in bugs developers never saw due to version differences between the jars provided in your JBOSS and the
one used to develop the GeoTools/GeoServer code.
data elsewhere.
Wondering, is this necessary or are you just trimming out the fat?
Hum, wondering why you'd want to, but anyways, GeoServer's log4j configuration files can be found in GEOSERVER_DATA_DIR/logs, maybe
you can tweak
This requires some custom code development. No rocket science, but hard
to justify since all the developers are using either Tomcat or Jetty
and no externally defined connection pools.
Interested in giving a crack to it? Or sponsoring this development?
This is technically possible thought. We need to make the username/password/roles lookup pluggable and then have someone write a
JAAS plugin. If anybody is interested in tacking the second part (JAAS
specific part) I'm ready to write the first one (make the security
subsystem more pluggable).
