[Geoserver-users] Geoserver War Tomcat 6 Mac OS X
Rodrigo C. Antonialli
Rio Claro - SP - Brasil
LinkedIn: http://www.linkedin.com/in/rcaprofile
Contato: (19) 9792-9820
rca.cirdan@anonymised.com
rcantonialli@anonymised.com
Skype: rc_antonialli
---------- Forwarded message ----------
Date: Thu, Nov 11, 2010 at 15:33
Subject: Geoserver War Tomcat 6 Mac OS X
To: geoserver@anonymised.com
Hi!!
I’m trying to deploy geoserver-2.0.2 on Tomcat 6.0.29 on Mac OS X (10.6.5… but I tried in 10.6.4 too) and tomcat crashes!!
A bootstrap jar opens in my Dock and some time later, tomcat crashes…
Looking inside catalina log, I found:
INFO: Deploying web application archive geoserver.war
11/11/2010 15:11:22 org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/Users/rcantonialli/Library/apache-tomcat-6.0.29/webapps/geoserver/WEB-INF/lib/servlet-api-2.4.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
I tried to deploy the geoserver war from Tomcat Manager page, and also put it manually at webapps folder and start tomcat… but I always get the error…
I just run geoserver on Mac downloading the installer for Mac OS… but if I do so, I`ll have 2 tomcats running… and my client for geoserver layers is running at tomcat 6 (I tried to put my projects folder inside webapps folder of geoserver installed from Mac OS installer but no sucess)…
Is there some known issue about Geoserver 2.0.2, Tomcat 6.0.29 and Mac OS X?? I’d really apreciate just to deploy Geoserver war and get things running into only one server!
Thanks for advance,
Hi Rodrigo,
I have used tomcat with geoserver on mac just fine. WHat is the actual error you are getting. The warning about the servlet api jar is fine and can be ignored. Is there another error?
-Justin
Hi!!
Thanks for advance,
Centralized Desktop Delivery: Dell and VMware Reference Architecture
Simplifying enterprise desktop deployment and management using
Dell EqualLogic storage and VMware View: A highly scalable, end-to-end
client virtualization framework. Read more!
http://p.sf.net/sfu/dell-eql-dev2dev
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
I “solved” the problem editing startup.sh script…
Just added:
export JAVA_OPTS=“-Djava.awt.headless=true”
rigth after the first line…
Then, I restarted tomcat and even with the “servlet api jar not loaded” message in the log, the “Bootstrap” didn’t showed up in the dock and the server didn’t crashed anymore…
I really don’t know, but I believe that there were some issue with another application deployed in tomcat
I`ve found this variable tip searching for “org.apache.catalina.startup.Bootstrap tomcat Mac” in Google…
So, I don’t know if it is related directly with Geoserver…
Thanks!!
On Fri, Nov 12, 2010 at 13:50, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Rodrigo,
-Justin
On Thu, Nov 11, 2010 at 11:18 AM, Rodrigo <rca.cirdan@anonymised.com.84…> wrote:
Hi!!
Thanks for advance,
Justin Deoliveira
