They are mutually exclusive, so yes, you have to embed the BBOX filter in
the FILTER.
Best regards,
Bart
When running the following:
http://localhost:8080/geoserver/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=vector%3Agv_collaboration_points%2Cvector%3Agv_collaboration_lines%2Cvector%3Agv_collaboration_polygons%2Cvector%3Apush_pins&MAXFEATURES=20&BBOX=-117.165737%2C32.749554%2C-117.155692%2C32.759598&filter=(<Filter><PropertyIsEqualTo><PropertyName>gv_layer_lst<%2FPropertyName><Literal>polygon1_ngauser<%2FLiteral><%2FPropertyIsEqualTo><%2FFilter>)
I get the following response:
<ServiceExceptionReport version="1.2.0" xsi:schemaLocation="
http://www.opengis.net/ogc
http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
e$B!]e(B
<ServiceException>
filter and bbox both specified but are mutually exclusive
</ServiceException>
</ServiceExceptionReport>
How can I run a geoserver WFS GetFeature against both a bbox and a filter
or
do I need to embed the bbox within the filter?
John J. Mitchell
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/_______________________________________________
Geoserver-users mailing list
Would anyone have an example of integrating bounding box with an attribute query all within the same filter parameter?
Below is a filter just against the attribute but I need to understand how to integrate the below filter with a bounding box filter.
filter = “(gv_layer_lst” +
loadVectorLayerName +
John
2008/8/26 John Mitchell <mitchelljj98@anonymised.com>
http://localhost:8080/geoserver/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=vector%3Agv_collaboration_points%2Cvector%3Agv_collaboration_lines%2Cvector%3Agv_collaboration_polygons%2Cvector%3Apush_pins&MAXFEATURES=20&BBOX=-117.165737%2C32.749554%2C-117.155692%2C32.759598&filter=(%3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3Egv_layer_lst%3C%2FPropertyName%3E%3CLiteral%3Epolygon1_ngauser%3C%2FLiteral%3E%3C%2FPropertyIsEqualTo%3E%3C%2FFilter%3E)
How can I run a geoserver WFS GetFeature against both a bbox and a filter or do I need to embed the bbox within the filter?
John J. Mitchell
John J. Mitchell
John Mitchell ha scritto:
filter =
"(<Filter><PropertyIsEqualTo><PropertyName>gv_layer_lst</PropertyName><Literal>"
"</Literal></PropertyIsEqualTo></Filter>)"
This is a valid POST request with the two filters and-ed. Justtake the
filter part and strip the ogc: prefixes, and you'll be able to use it
as a FILTER=xxx GET parameter:
<wfs:GetFeature service="WFS" version="1.0.0"
outputFormat="GML2"
xmlns:topp="http://www.openplans.org/topp"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<wfs:Query typeName="topp:states">
<ogc:PropertyName>topp:STATE_NAME</ogc:PropertyName>
<ogc:PropertyName>topp:PERSONS</ogc:PropertyName>
<ogc:Filter>
<ogc:And>
<ogc:BBOX>
<ogc:PropertyName>the_geom</ogc:PropertyName>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
<gml:coordinates>-75.102613,40.212597
-72.361859,41.512517</gml:coordinates>
</gml:Box>
</ogc:BBOX>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>STATE_NAME</ogc:PropertyName>
<ogc:Literal>New York</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:And>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Hope this helps
