A few days ago I installed GeoServer 2.2.4 on a Windows server as a service.
I have been reading through some of the documentation and went through the
basic configuration. I worked through one of the shapefile examples, and
then published one of my own shapefiles. All of this was done using the web
admin page. I was having problems getting my data to display properly, so I
was doing some research on the web. I ran across a post that suggested
having the data_dir in a different location than the program files. So, I
moved it to another location on the same drive and changed the
GEOSERVER_DATA_DIR system variable to the new location. I could not get the
web admin page to open, so I manually stopped the service. When I tried to
restart the service, I got "Error 1053: The service did not respond to the
start or control request in a timely fashion". I tried moving the data_dir
to the old location and changing the system variable back, but it still did
not work. So, I uninstalled the GeoServer program completely. I
reinstalled the GeoServer program again as a service and used the default
data_dir, which is under the program installation folder. The service will
not start. I have tried to start it manually several times and each time I
get the Error 1053.
Any suggestions that you may have are GREATLY appreciated.
Jerome A. Wendell
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoServer-Will-Not-Start-tp5034090.html
