Hello,
Is it possible to run Geoserver Windows Service on a Windows 2008 R2 machine (64-bit).
What I have done so far is created a installer with a different wrapper.exe (from http://www.krenger.ch/blog/java-service-wrapper-3-5-7-for-windows-x64/). This is a 64-bit build from the 32-bit community wrapper. The installer is created successfully, can be installed on W2K8, I have selected the 64-bit java JRE. Geoserver runs but now comes the problem. I have installed the Oracle plugin with the OJDBC14_g.jar (from oracle installation folder) but Oracle won’t work. Has any one a idea on how to make this work?
Met vriendelijke groet,
Lucas Heezen
Covadis b.v.
t: 026 3616600
Geograaf 12
f: 026 3612317
6921 EW Duiven
