Hello everybody,
I am trying the Geoserver the first time and just wondering regarding a very poor general performance. After my installation of the current stabele release (2.6.1) on a tomcat 7.0.52 with Oracle Java 8. For my server I use an Ubunutu 14.04 LTS. So far I did not configured any layer or database. Nevertheless when I try to load any side, e.g. settings, it takes very long to load the page, approx. 30s!!! I guess there is any issue but I could not found any hint. I already increased the the memory for my tomcat installation (Free memory: 862.67 MB Total memory: 1007.37 MB Max memory: 3035.37 MB).
Is the current behaviour correct? If not what can I check? For me, the log files does show any issues.
========== tomcat log ==========
Dec 31, 2014 10:23:39 AM org.apache.catalina.startup.ClassLoaderFactory validateFile
WARNING: Problem with directory [/usr/share/tomcat7/common/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/common], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/server/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/server], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/shared/classes], exists: [false], isDirectory: [false], canRead: [false]
WARNING: Problem with directory [/usr/share/tomcat7/shared], exists: [false], isDirectory: [false], canRead: [false]
Dec 31, 2014 10:23:40 AM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler [“http-bio-8080”]
Dec 31, 2014 10:23:40 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 733 ms
Dec 31, 2014 10:23:40 AM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Dec 31, 2014 10:23:40 AM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.52 (Ubuntu)
Dec 31, 2014 10:23:40 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/host-manager.xml
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/manager.xml
Dec 31, 2014 10:23:40 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /var/lib/tomcat7/webapps/geoserver.war
31 Dec 10:23:49 DEBUG [geoserver.global] - Found Java environment variable GEOSERVER_DATA_DIR to be unset
31 Dec 10:23:49 DEBUG [geoserver.global] - Found Servlet context parameter GEOSERVER_DATA_DIR to be unset
31 Dec 10:23:49 DEBUG [geoserver.global] - Found System environment variable GEOSERVER_DATA_DIR to be unset
31 Dec 10:23:49 DEBUG [geoserver.global] - Found Java environment variable GEOSERVER_DATA_ROOT to be unset
31 Dec 10:23:49 DEBUG [geoserver.global] - Found Servlet context parameter GEOSERVER_DATA_ROOT to be unset
31 Dec 10:23:49 DEBUG [geoserver.global] - Found System environment variable GEOSERVER_DATA_ROOT to be unset
31 Dec 10:23:49 INFO [geoserver.global] - Falling back to embedded data directory: /var/lib/tomcat7/webapps/geoserver/data
Dec 31, 2014 10:23:49 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup ‘XStreamPersisterInitializer’, but ApplicationContext is unset.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
31 Dec 10:23:51 INFO [geoserver.global] - Falling back to embedded data directory: /var/lib/tomcat7/webapps/geoserver/data
Dec 31, 2014 10:23:51 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup ‘GeoServerSecurityProvider’, but ApplicationContext is unset.
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘restricted’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘polygon’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘point’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘green’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘raster’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘burg’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘giant_polygon’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘dem’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘tiger_roads’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘simple_streams’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘pophatch’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘line’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘rain’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘capitals’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘poi’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘simple_roads’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘population’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘grass’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded style ‘cite_lakes’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded default workspace it.geosolutions
31 Dec 10:23:52 INFO [org.geoserver] - Loaded workspace ‘it.geosolutions’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded workspace ‘nurc’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded workspace ‘topp’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded workspace ‘sf’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded workspace ‘sde’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded workspace ‘cite’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded workspace ‘tiger’
31 Dec 10:23:52 INFO [org.geoserver] - Loaded store ‘mosaic’, enabled
31 Dec 10:23:52 INFO [org.geoserver] - Loaded coverage store ‘mosaic’
31 Dec 10:23:53 INFO [org.geoserver] - Loaded coverage ‘mosaic’, enabled
31 Dec 10:23:54 WARN [imagemosaic.Utils] - Unable to find sample image for path /var/lib/tomcat7/webapps/geoserver/data/coverages/mosaic_sample/sample_image
31 Dec 10:23:54 WARN [gce.imagemosaic] - Unable to find sample image for path file:/var/lib/tomcat7/webapps/geoserver/data/coverages/mosaic_sample/mosaic.shp
31 Dec 10:23:54 INFO [org.geoserver] - Loaded layer ‘mosaic’
31 Dec 10:23:54 INFO [org.geoserver] - Loaded store ‘arcGridSample’, enabled
31 Dec 10:23:54 INFO [org.geoserver] - Loaded coverage store ‘arcGridSample’
31 Dec 10:23:54 INFO [org.geoserver] - Loaded coverage ‘Arc_Sample’, enabled
31 Dec 10:23:54 INFO [org.geoserver] - Loaded coverage ‘arcGridSample’
31 Dec 10:23:54 INFO [org.geoserver] - Loaded layer ‘Arc_Sample’
31 Dec 10:23:54 INFO [org.geoserver] - Loaded store ‘img_sample2’, disabled
31 Dec 10:23:54 INFO [org.geoserver] - Loaded coverage store ‘img_sample2’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded coverage ‘Pk50095’, disabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded coverage ‘img_sample2’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘Pk50095’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded store ‘worldImageSample’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded coverage store ‘worldImageSample’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded coverage ‘Img_Sample’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded coverage ‘worldImageSample’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘Img_Sample’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded store ‘states_shapefile’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded data store ‘states_shapefile’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘states’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘states_shapefile’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘states’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded store ‘taz_shapes’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded data store ‘taz_shapes’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘tasmania_water_bodies’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘tasmania_water_bodies’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘tasmania_cities’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘tasmania_cities’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘tasmania_roads’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘tasmania_roads’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘tasmania_state_boundaries’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘tasmania_state_boundaries’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded store ‘sfdem’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded coverage store ‘sfdem’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded coverage ‘sfdem’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘sfdem’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded store ‘sf’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded data store ‘sf’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘streams’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘sf’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘streams’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘archsites’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘archsites’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘restricted’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘restricted’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘roads’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘roads’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘bugsites’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘bugsites’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded store ‘nyc’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded data store ‘nyc’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘poly_landmarks’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘nyc’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘poly_landmarks’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘poi’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘poi’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘giant_polygon’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘giant_polygon’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded feature type ‘tiger_roads’, enabled
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer ‘tiger_roads’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer group ‘tiger-ny’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer group ‘tasmania’
31 Dec 10:23:55 INFO [org.geoserver] - Loaded layer group ‘spearfish’
31 Dec 10:23:56 INFO [storage.DefaultStorageFinder] - ***************************************************************************************
31 Dec 10:23:56 INFO [storage.DefaultStorageFinder] - *** Reverting to java.io.tmpdir null for storage. Please set GEOWEBCACHE_CACHE_DIR. ***
31 Dec 10:23:56 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in ‘/tmp/tomcat7-tomcat7-tmp/geowebcache’
31 Dec 10:23:56 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
31 Dec 10:23:56 INFO [gwc.layer] - GeoServer TileLayer store base directory is: /var/lib/tomcat7/webapps/geoserver/data/gwc-layers
31 Dec 10:23:56 INFO [gwc.layer] - Loading tile layers from /var/lib/tomcat7/webapps/geoserver/data/gwc-layers
31 Dec 10:23:56 INFO [gwc.layer] - GWC configuration based on GeoServer’s Catalog loaded successfuly
31 Dec 10:23:56 WARN [config.XMLConfiguration] - Found no configuration file in config directory, will create one at ‘/tmp/tomcat7-tomcat7-tmp/geowebcache/geowebcache.xml’ from template jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/gwc-core-1.6.0.jar!/geowebcache_empty.xml
31 Dec 10:23:56 INFO [config.XMLConfiguration] - Configuration file validated fine.
31 Dec 10:23:56 INFO [config.XMLConfiguration] - Initializing GridSets from /tmp/tomcat7-tomcat7-tmp/geowebcache
31 Dec 10:23:56 INFO [config.XMLConfiguration] - Initializing layers from /tmp/tomcat7-tomcat7-tmp/geowebcache
31 Dec 10:23:56 INFO [layer.TileLayerDispatcher] - Configuration /tmp/tomcat7-tomcat7-tmp/geowebcache contained no layers.
31 Dec 10:23:56 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: /tmp/tomcat7-tomcat7-tmp/geowebcache/geowebcache-diskquota.xml
31 Dec 10:23:56 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
31 Dec 10:23:56 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
31 Dec 10:23:56 INFO [diskquota.DiskQuotaMonitor] - 22 layers attached to global quota 500.0 MB
31 Dec 10:23:56 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
31 Dec 10:23:56 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
31 Dec 10:23:56 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
31 Dec 10:23:56 INFO [org.geoserver] - Loaded service ‘wms’, enabled
31 Dec 10:23:56 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
31 Dec 10:23:56 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/] onto handler ‘dispatcher’
31 Dec 10:23:56 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
31 Dec 10:23:56 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
31 Dec 10:23:56 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
31 Dec 10:23:57 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 14 paths
31 Dec 10:23:57 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
31 Dec 10:23:57 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
31 Dec 10:23:58 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/icon//] onto handler ‘kmlIconService’
31 Dec 10:23:58 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/] onto handler ‘dispatcher’
31 Dec 10:23:58 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler ‘dispatcher’
31 Dec 10:23:58 INFO [geoserver.global] - Falling back to embedded data directory: /var/lib/tomcat7/webapps/geoserver/data
31 Dec 10:23:58 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/] onto handler ‘dispatcher’
31 Dec 10:23:58 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler ‘dispatcher’
31 Dec 10:23:58 INFO [org.geoserver] - GeoServer configuration lock is enabled
31 Dec 10:23:59 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/] onto handler ‘dispatcher’
31 Dec 10:23:59 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
31 Dec 10:24:00 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/] onto handler ‘dispatcher’
31 Dec 10:24:00 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
31 Dec 10:24:00 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
31 Dec 10:24:04 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
31 Dec 10:24:04 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/] onto handler ‘dispatcher’
31 Dec 10:24:04 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
31 Dec 10:24:04 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler ‘dispatcher’
31 Dec 10:24:04 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
31 Dec 10:24:04 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
31 Dec 10:24:05 INFO [geoserver.security] - Start reloading user/grous for service named default
31 Dec 10:24:05 INFO [geoserver.security] - Reloading user/groups successful for service named default
Dec 31, 2014 10:24:05 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory /var/lib/tomcat7/webapps/ROOT
Dec 31, 2014 10:24:05 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler [“http-bio-8080”]
Dec 31, 2014 10:24:05 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 25650 ms
