[Geoserver-users] GeoServer WMS request processing delay
We have a deployment of Geoserver 2.1 on weblogic and control flow module extension is not installed on it. Now the web client is sending quite a high number of WMS requests to the Geoserver. In the logs I see the messages as pasted below with the requests starting with Request: getServiceInfo. The client is sending all requests in parallel but there is a big time gap(~1 min) between the first and the last “Request: getServiceInfo” in the log. As a result the impage rendering on the client is taking over one minute. I would like to know:
  1. The time mentioned against each Request: getServiceInfo message is the timestamp when GeoServer is receiving the request or starting to processing them?
  2. By default, can GeoServer receive and hold back the requests in a queue/memory and then slowly process them? We are seeing five Request: getServiceInfo messages at a time. Which parameter is controlling that five requests will be processed at a time?
    Thanks in advance for any help/suggestion in this regard.
Log
2014-08-22 11:01:01,978 INFO [org.geoserver.wms] -
2014-08-22 11:01:01,978 DEBUG [org.geotools.styling] - number of fts set 1
2014-08-22 11:01:01,978 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2014-08-22 11:01:01,993 DEBUG [org.geotools.styling] - number of fts set 1
2014-08-22 11:01:01,993 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2014-08-22 11:01:02,056 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2014-08-22 11:01:02,056 DEBUG [org.geotools.styling] - number of fts set 1
2014-08-22 11:01:02,056 DEBUG [org.geotools.rendering] - Computed scale denominator: 136494.6933663861
2014-08-22 11:01:02,056 DEBUG [org.geotools.rendering] - processing 1 stylers for http://sw.opengeo.org/iccsa:ICC_SA_LAYER_WOA_COVERAGE
2014-08-22 11:01:02,056 DEBUG [org.geotools.rendering] - creating rules for scale denominator - 136,494.693
2014-08-22 11:01:02,056 DEBUG [org.geotools.rendering] - Expanding rendering area by 2 pixels to consider stroke width
2014-08-22 11:01:02,056 DEBUG [org.geotools.rendering] - Querying layer http://sw.opengeo.org/iccsa:ICC_SA_LAYER_WOA_COVERAGE with bbox: ReferencedEnvelope[-4.4831085205078125 : -4.3938446044921875, 55.77618707932433 : 55.82635919396237]
2014-08-22 11:01:02,056 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2014-08-22 11:01:02,056 TRACE [org.geotools.core] - ENTRY 4
2014-08-22 11:01:02,056 DEBUG [org.geotools.filter] - exporting PropertyName
2014-08-22 11:01:02,056 DEBUG [org.geotools.jdbc] - SELECT ID,NAME,LOCATION as LOCATION FROM DW_GIS_STAGING.WOA_COVERAGE WHERE SDO_FILTER(LOCATION, ?, ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’
2014-08-22 11:01:02,056 DEBUG [org.geotools.data.oracle.sdo] - Using layer SRID: 27700
2014-08-22 11:01:02,056 DEBUG [org.geotools.jdbc] - Setting parameter 1 as MDSYS.SDO_GEOMETRY(2003,27700,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(244351.8087203098,656245.6991104394,250142.47294718216,662024.8961483135))
2014-08-22 11:01:02,071 DEBUG [org.geotools.jdbc] - 1 = POLYGON ((244351.8087203098 656245.6991104394, 244351.8087203098 662024.8961483135, 250142.47294718216 662024.8961483135, 250142.47294718216 656245.6991104394, 244351.8087203098 656245.6991104394))
2014-08-22 11:01:02,071 DEBUG [org.geotools.styling] - number of fts set 1
2014-08-22 11:01:02,071 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
Thanks & Regards,
Samyajit Talukdar
Privileged/Confidential information may be contained in this Email and any files transmitted with it. If you are not the intended recipient you should not retain, copy or use this Email for any purpose or disclose all or part of its contents to any person. If you have received this Email in error please notify the postmaster and sender immediately and delete this Email from your system.
Opinions, conclusions and other information in this message that do not relate to the official business of Scottish Water (“SW”), Scottish Water Solutions Ltd (“SWS”) or Scottish Water Solutions 2 Ltd (“SWS2”) shall be understood as neither given nor endorsed by them. The contents of Emails sent and received by SW, SWS and SWS2 are monitored.
WARNING: Although SW, SWS and SWS2 have taken reasonable precautions to ensure no viruses or other malicious software are present, SW, SWS and SWS2 cannot accept responsibility for any loss or damage arising from the use of this Email or attachments however caused. The recipient should therefore check this Email and any attachments for the presence of viruses or other malicious software.
Scottish Water
www.scottishwater.co.uk
www.scottishwatersolutions.co.uk
postmaster@anonymised.com
