[Geoserver-users] GeoServer won't start after configuration change.
Hello,
I’m having a problem with GeoServer 2.1.1 on Red Hat Enterprise Linux after making some configuration changes through the web interface. It won’t start up correctly.
In particular, I was looking through the GeoWebCache settings and clicked on the option “Enable direct WMS integration”. Afterwards it wasn’t working correctly so I tried to restart the server, and now it just shows this when browsing to the url after starting up:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/geoserver
Powered by jetty://
I have this same option checked in my local GeoServer instance on my laptop which is running Windows 7 and have not run into this issue there.
Below is part of the starup.log file. I have highlighted parts which I think may be relevant. Could this be a Linux file permissions issue or is it something else?
Eric
21 Jul 15:38:48 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [jar:file:/opt/geoserver-2.1.1/webapps/geoserver/WEB-INF/lib/gwc-2.1.1.jar!/geowebcache-geoserver-context.xml]: Cannot resolve reference to bean ‘DiskQuotaStore’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘DiskQuotaStore’ defined in URL [jar:file:/opt/geoserver-2.1.1/webapps/geoserver/WEB-INF/lib/gwc-2.1.1.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is com.sleepycat.je.EnvironmentLockedException: (JE 4.1.7) /opt/geoserver/data_dir/gwc/diskquota_page_store The environment cannot be locked for single writer access. ENV_LOCKED: The je.lck file could not be locked. Environment is invalid and must be closed.
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘DiskQuotaStore’ defined in URL [jar:file:/opt/geoserver-2.1.1/webapps/geoserver/WEB-INF/lib/gwc-2.1.1.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is com.sleepycat.je.EnvironmentLockedException: (JE 4.1.7) /opt/geoserver/data_dir/gwc/diskquota_page_store The environment cannot be locked for single writer access. ENV_LOCKED: The je.lck file could not be locked. Environment is invalid and must be closed.
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1337)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
… 43 more
Caused by: com.sleepycat.je.EnvironmentLockedException: (JE 4.1.7) /opt/geoserver/data_dir/gwc/diskquota_page_store The environment cannot be locked for single writer access. ENV_LOCKED: The je.lck file could not be locked. Environment is invalid and must be closed.
at com.sleepycat.je.log.FileManager.(FileManager.java:350)
at com.sleepycat.je.dbi.EnvironmentImpl.(EnvironmentImpl.java:439)
at com.sleepycat.je.dbi.EnvironmentImpl.(EnvironmentImpl.java:340)
at com.sleepycat.je.dbi.DbEnvPool.getEnvironment(DbEnvPool.java:195)
at com.sleepycat.je.Environment.makeEnvironmentImpl(Environment.java:229)
at com.sleepycat.je.Environment.(Environment.java:211)
at com.sleepycat.je.Environment.(Environment.java:165)
at org.geowebcache.diskquota.storage.EntityStoreBuilder.buildEntityStore(EntityStoreBuilder.java:61)
at org.geowebcache.diskquota.storage.BDBQuotaStore.configure(BDBQuotaStore.java:158)
at org.geowebcache.diskquota.storage.BDBQuotaStore.startUp(BDBQuotaStore.java:117)
at org.geowebcache.diskquota.storage.BDBQuotaStore.afterPropertiesSet(BDBQuotaStore.java:102)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1368)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1334)
… 53 more
9524 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,file:/opt/geoserver-2.1.1/webapps/geoserver/}
… 43 more
… 53 more
9526 [main] ERROR org.mortbay.log - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [jar:file:/opt/geoserver-2.1.1/webapps/geoserver/WEB-INF/lib/gwc-2.1.1.jar!/geowebcache-geoserver-context.xml]: Cannot resolve reference to bean ‘DiskQuotaStore’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘DiskQuotaStore’ defined in URL [jar:file:/opt/geoserver-2.1.1/webapps/geoserver/WEB-INF/lib/gwc-2.1.1.jar!/geowebcache-diskquota-context.xml]: Invocation of init method failed; nested exception is com.sleepycat.je.EnvironmentLockedException: (JE 4.1.7) /opt/geoserver/data_dir/gwc/diskquota_page_store The environment cannot be locked for single writer access. ENV_LOCKED: The je.lck file could not be locked. Environment is invalid and must be closed.:
9531 [main] INFO org.mortbay.log - Opened /opt/geoserver-2.1.1/logs/2011_07_21.request.log
9542 [main] WARN org.mortbay.log - failed SelectChannelConnector@anonymised.com:8080
java.net.BindException: Address already in use
at sun.nio.ch.Net.bind(Native Method)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:126)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:59)
at org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChannelConnector.java:205)
at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:304)
at org.mortbay.jetty.Server.doStart(Server.java:233)
9542 [main] WARN org.mortbay.log - failed Server@anonymised.com
9543 [main] WARN org.mortbay.log - EXCEPTION
