I published a coverage (Geotiff) using WCS 1.1.1 service. However, When I
download the WCS geotiff format file, the dimensions change.
For example, the source geotiff coverage dimension is: 5000*2000
the WCS geotiff format coverage dimension is: 2000*5000
WCS coverage still projected correctly, but I dont' know why the dimension
change. Anyone has the same problem?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoSever-WCS-1-1-0-dimension-change-tp5069629.html
Ciao,
this is strange. Are you sure the data does not have the axes
inverted? It looks like there is a switch from lon,lat to lat-lon.
Can you please check this in the output geotiff?
It would also help to share the request you made and probably a
portion of the data to show evidence of the problem.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Tue, Jul 30, 2013 at 3:59 PM, dywdaniel <yunwei.dong@anonymised.com> wrote:
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It's a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-users mailing list
