[Geoserver-users] Geosrever 2.13.3-2.15.0 ImageMosaic overlapping transparent from alpha band
Hi All,
I'm migrating from OracleJDK1.7/Geoserver2.8.3 to OpenJDK11/GeoServer2.15.0,
and have issues with ImageMosiac layers. In short words - can't configure
two geotiffs to glue together where they overlap.
Tried and searched everything, installed 10 versions of Geoserver and
figured out it stopped working in Geoserver 2.13.3 (GeoTools 19.3). In
GeoTools release notes I found that some transparency issues were fixed
then, but it stopped working for me.
I understand that I have alpha band in my files, not "no data" so popular
problems with no-data and enabling JAI-EXT, setting transparency color is
not the problem/solution.
It works fine with no configuration (just clean geoserver install, create
store and publish layer, only set names) with JAVA8 / Geoserver 2.8.3,
2.12.5., 2.13.0, 2.13.2 but not 2.13.3 and next releases.
Here are details and samples:
https://gis.stackexchange.com/questions/313758/geoserver-2-13-3-2-15-0-imagemosaic-blank-transparent-spaces-with-overlapping
<https://gis.stackexchange.com/questions/313758/geoserver-2-13-3-2-15-0-imagemosaic-blank-transparent-spaces-with-overlapping&gt;
Regards
Lukas B
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
Hi Lukas,
can you open a ticket at https://osgeo-org.atlassian.net/projects/GEOS/summary
and attache the tiff files there? I don’t know about others, but I’m not particularly eager
to give my mail address to random web sites
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
Thank you for your response. You have right, that was not the best site I could upload the files with, I updated it with direct download
And created the ticket and attached files at https://osgeo-org.atlassian.net/browse/GEOS-9143
Lukas
Sent: Friday, March 8, 2019 4:07 PM
To: Lukas B. lukasz.bocianiak@anonymised.com
Cc: GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Geosrever 2.13.3-2.15.0 ImageMosaic overlapping transparent from alpha band
Hi Lukas,
On Tue, Mar 5, 2019 at 1:29 PM Lukas B. <lukasz.bocianiak@anonymised.com> wrote:
Hi All,
I’m migrating from OracleJDK1.7/Geoserver2.8.3 to OpenJDK11/GeoServer2.15.0,
and have issues with ImageMosiac layers. In short words - can’t configure
I understand that I have alpha band in my files, not “no data” so popular
<https://gis.stackexchange.com/questions/313758/geoserver-2-13-3-2-15-0-imagemosaic-blank-transparent-spaces-with-overlapping>
Regards
Lukas B
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.comet
Try disabling “Tile Recycling” under Settings/Image Processing.
I had a similar issue on a 2.12.5 instance recently and that fixed it.
Gabriel
Gabriel Roldán
Thank you, I checked the option and it is unchecked (by default I think), changing it doesn’t help
I tested the 2.12.5 version earlier and it works properly in my case with clean install of Geoserver, it breaks after 2.13.2
LB
Sent: Saturday, March 9, 2019 2:12 AM
To: Łukasz Bocianiak lukasz.bocianiak@anonymised.com
Cc: GeoServer Mailing List List geoserver-users@anonymised.comorge.net
Gabriel
