[Geoserver-users] geotiff layer not rendered in the preview when sld rules are used
Dear Geoserver users,
I'm using GeoServer 2.15.0
I have the following geotiff file
gdalinfo:
________________________
Driver: GTiff/GeoTIFF
Files: test2_SRT1.tif
Size is 1200, 1400
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (4.523391511849696,47.848989216319268)
Pixel Size = (0.013294347480251,-0.009131359599727)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 4.5233915, 47.8489892) ( 4d31'24.21"E, 47d50'56.36"N)
Lower Left ( 4.5233915, 35.0650858) ( 4d31'24.21"E, 35d 3'54.31"N)
Upper Right ( 20.4766085, 47.8489892) ( 20d28'35.79"E, 47d50'56.36"N)
Lower Right ( 20.4766085, 35.0650858) ( 20d28'35.79"E, 35d 3'54.31"N)
Center ( 12.5000000, 41.4570375) ( 12d30' 0.00"E, 41d27'25.33"N)
Band 1 Block=1200x1 Type=Float32, ColorInterp=Gray
NoData Value=0
_____________________________
file:
TIFF image data, little-endian, direntries=17, height=1400, bps=32, compression=none, PhotometricIntepretation=BlackIsZero, width=1200
When I publish it in geoserver, using the standard "raster" sld style, I can see it in the "OpenLayers" link available from the "Layer Preview" menu
On the other side, nothing is shown (the "OpenLayers" map becomes blank) when I use a slightly more complex sld like the following one:
______________________________________
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/sld StyledLayerDescriptor.xsd"
xmlns="http://www.opengis.net/sld&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
xmlns:xlink="http://www.w3.org/1999/xlink&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
<NamedLayer>
<Name>Two color gradient</Name>
<UserStyle>
<Title>SLD Cook Book: three color gradient</Title>
<FeatureTypeStyle>
<Rule>
<RasterSymbolizer>
<ColorMap>
<ColorMapEntry color="#008000" quantity="0" />
<ColorMapEntry color="#663333" quantity="1" />
<ColorMapEntry color="#934535" quantity="100" />
</ColorMap>
</RasterSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
_________________________________________
What is strange is that style editor, when I switch, from the "data" tab, to the "Layer Preview" tab, I can regularly see the map colored acccording to the sld.
Here follow the geoserver log.
Any help is really appreciated, thank you very much
Ivan
2020-12-26 14:42:39,348 INFO [geoserver.wms] -
Request: getMap
Angle = 0.0
BaseUrl = http://xxx.xxx.xxx.xxx:8080/geoserver/
Bbox = SRSEnvelope[4.523391511849696 : 20.476608488150305, 35.06508577670113 : 47.84898921631927]
BgColor = java.awt.Color[r=255,g=255,b=255]
Buffer = 0
CQLFilter = null
Crs = GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
Elevation =
Env = {}
Exceptions = SE_XML
FeatureId = null
FeatureVersion = null
Filter = null
Filters = null
Format = application/openlayers
FormatOptions = {}
Get = true
Height = 615
Interpolations =
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Palette = null
RawKvp = {REQUEST=GetMap, SRS=EPSG:4326, FORMAT=application/openlayers, BBOX=4.523391511849696,35.06508577670113,20.476608488150305,47.84898921631927, VERSION=1.1.0, SERVICE=WMS, WIDTH=768, HEIGHT=615, LAYERS=dpc:test2_SRT1}
RemoteOwsType = null
RemoteOwsURL = null
Request = GetMap
RequestCharset = UTF-8
ScaleMethod = null
Sld = null
SldBody = null
SldVersion = null
SortBy = null
SortByArrays = null
SRS = EPSG:4326
StartIndex = null
StyleBody = null
StyleFormat = sld
Styles = [StyleImpl[ name=raster2]]
StyleUrl = null
StyleVersion = null
Tiled = false
TilesOrigin = null
Time =
Transparent = false
ValidateSchema = false
Version = 1.1.0
ViewParams = null
Width = 768
2020-12-26 14:42:39,548 INFO [geoserver.wms] -
Request: getServiceInfo
2020-12-26 14:42:39,559 INFO [geoserver.wms] -
Request: getMap
Angle = 0.0
Bbox = SRSEnvelope[4.06494140625 : 20.93994140625, 34.705810546875 : 48.218994140625]
Buffer = 0
CQLFilter = null
Elevation =
Env = {}
Exceptions = application/vnd.ogc.se_inimage
FeatureId = null
Filter = null
Filters = null
Format = image/jpeg
FormatOptions = {}
Get = true
Height = 615
Interpolations =
MaxFeatures = null
Palette = null
RawKvp = {EXCEPTIONS=application/vnd.ogc.se_inimage, REQUEST=GetMap, FORMAT=image/jpeg, SRS=EPSG:4326, BBOX=4.06494140625,34.705810546875,20.93994140625,48.218994140625, VERSION=1.1.1, STYLES=, SERVICE=WMS, WIDTH=768, HEIGHT=615, TRANSPARENT=true, LAYERS=dpc:test2_SRT1}
RemoteOwsURL = null
Request = GetMap
ScaleMethod = null
Sld = null
SldBody = null
SldVersion = null
SortBy = null
SortByArrays = null
SRS = EPSG:4326
StartIndex = null
StyleBody = null
StyleFormat = sld
StyleUrl = null
StyleVersion = null
Tiled = false
TilesOrigin = null
Time =
Transparent = true
Version = 1.1.1
ViewParams = null
Width = 768
2020-12-26 14:42:39,680 INFO [geoserver.servlets] - OutputStream was successfully aborted.
2020-12-26 14:42:39,680 ERROR [geoserver.ows] -
javax.imageio.IIOException: Invalid argument to native writeImage
at com.sun.imageio.plugins.jpeg.JPEGImageWriter.writeImage(Native Method)
at com.sun.imageio.plugins.jpeg.JPEGImageWriter.writeOnThread(JPEGImageWriter.java:1067)
at com.sun.imageio.plugins.jpeg.JPEGImageWriter.write(JPEGImageWriter.java:363)
at org.geotools.image.ImageWorker.writeJPEG(ImageWorker.java:4002)
at org.geoserver.wms.map.JPEGMapResponse.formatImageOutputStream(JPEGMapResponse.java:69)
at org.geoserver.wms.map.RenderedImageMapResponse.write(RenderedImageMapResponse.java:112)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:1029)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:52)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:890)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:634)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:357)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:270)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:79)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:200)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:526)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:678)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:408)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:861)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1579)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
2020-12-26 14:42:39,683 INFO [geoserver.ows] - Problem writing exception information back to calling client:
at javax.imageio.ImageWriter.write(ImageWriter.java:615)
at javax.imageio.ImageIO.doWrite(ImageIO.java:1622)
at javax.imageio.ImageIO.write(ImageIO.java:1588)
at org.geoserver.wms.WMSServiceExceptionHandler.handleImageException(WMSServiceExceptionHandler.java:241)
at org.geoserver.wms.WMSServiceExceptionHandler.handleServiceException(WMSServiceExceptionHandler.java:147)
at org.geoserver.ows.Dispatcher.handleServiceException(Dispatcher.java:1806)
at org.geoserver.ows.Dispatcher.exception(Dispatcher.java:1753)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:274)
HI..
it seems it is a problem of the jpeg driver
never happened to me before
