Dear Geoserver-users,
As someone new to Geoserver, I don’t know if what I ask is a bug, a pebkac, or simply not possible:
I’ve published two GeoTIFFs to my Geoserver install (both on ESPG:27700) and added them as non-base layers on a Google Map base in OpenLayers.
As you can see from the image, where Geoserver is reprojecting the tiffs, it’s leaving a honking great black border. I’ve added transparency requests on the layer, but they appear to be ignored.
Could anyone suggest what I’ve done wrong?
Associated layer code:
tg04v1 = new OpenLayers.Layer.WMS(
“TG04V1”, serverURL,
LAYERS: ‘test:TG04_CopyRaster1’,
STYLES: ‘’,
format: ‘image/png8’,
transparent: true,
tiled: !pureCoverage,
tilesOrigin : map.maxExtent.left + ‘,’ + map.maxExtent.bottom
buffer: 0,
displayOutsideMaxExtent: true,
isBaseLayer: false,
transparent: true,
opacity: 0.9,
visibility: false
Mark Hammond
Web Software Developer
British Trust for Ornithology, The Nunnery, Thetford, Norfolk, IP24 2PU, UK
Tel: +44 (0)1842 750050; Fax: +44 (0)1842 750030
’ Hit any user to continue. ’
