[Geoserver-users] GeoTIFFs verus JP2
JPEG2000 format supports up to 16384 components (bands) but all JPEG2000 libraries probably not. Those working with medical imaging or multispectral scanners appreciate this but it is also practical for storing multichannel satellite images. Bands do not even need to have same extents or resolutions but I do not recommend to create such images because few software can utilize them.
It you want to trial, take a multiband TIFF and convert it into JPEG2000 with Kakadu demo program “kdu_show”. You can get it for free from http://www.kakadusoftware.com/index.php?option=com_content&task=view&id=26&Itemid=22 It will be harder to find a good viewer for showing your multichannel JPEG200 images but you can have a try with QGis or OpenEV.
PHOTOMETRIC=YCBCR works only for 3-band images.
In theory it feels clever to use RGBI originals and pick either true colour or CIR presenstations out of them on-the-fly. It means 4 physical bands instead of 6 when compared to having separate RGB and CIR versions. However, I have been disappointed with this approach because it is hard to adjust the RGBI bands so that both RGB and CIR looks good without further adjustment in the viewer or by the server. And as discussed, three band images compress well with YCBCR and the saving in disk space is not necessarily so great. Situation is different with for example Landsat images with 7 thematic bands. I can’t even count how many different RGB combinations there are.
-Jukka Rahkonen-
Jonathan Moules wrote:
Hi Both,
Thanks for the quick and helpful replies. I’ll do some experimentation with these things. And there I was thinking I’d figured out GDAL. :slight_smile: You might want to put some of this stuff in your “GeoServer on Steroids” presentation.
I’d thought that overviews were compressed - useful to know they’re not; that’ll be a saving of a couple of GB.
I could have sworn someone told me JP2 couldn’t do four bands. Hmmm. For now I’ll stick with GeoTIFFs - I don’t have any 4 band JP2’s and our vendor wasn’t able to create them (nor can FME), so I can’t provide a sample I’m afraid.
Will the PHOTOMETRIC= YCBCR work with a four band RGBI?
The GDALINFO for a source Geotiff is:
Driver: GTiff/GeoTIFF
Files: SP4044.tif
SP4044.tfw
Size is 8000, 8000
Coordinate System is:
PROJCS[“OSGB 1936 / British National Grid”,
GEOGCS[“OSGB 1936”,
DATUM[“OSGB_1936”,
SPHEROID[“Airy 1830”,6377563.396,299.3249753150316,
AUTHORITY[“EPSG”,“7001”]],
AUTHORITY[“EPSG”,“6277”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4277”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,49],
PARAMETER[“central_meridian”,-2],
PARAMETER[“scale_factor”,0.9996012717],
PARAMETER[“false_easting”,400000],
PARAMETER[“false_northing”,-100000],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“27700”]]
Origin = (440000.000000000000000,245000.000000000000000)
Pixel Size = (0.125000000000000,-0.125000000000000)
Metadata:
TIFFTAG_XRESOLUTION=72
TIFFTAG_YRESOLUTION=72
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 440000.000, 245000.000) ( 1d24’57.45"W, 52d 6’5.31"N)
Lower Left ( 440000.000, 244000.000) ( 1d24’57.87"W, 52d 5’32.94"N)
Upper Right ( 441000.000, 245000.000) ( 1d24’4.89"W, 52d 6’5.04"N)
Lower Right ( 441000.000, 244000.000) ( 1d24’5.32"W, 52d 5’32.68"N)
Center ( 440500.000, 244500.000) ( 1d24’31.39"W, 52d 5’48.99"N)
Band 1 Block=8000x32 Type=Byte, ColorInterp=Red
Band 2 Block=8000x32 Type=Byte, ColorInterp=Green
Band 3 Block=8000x32 Type=Byte, ColorInterp=Blue
Band 4 Block=8000x32 Type=Byte, ColorInterp=Undefined
Thanks again,
Jonathan
On 12 November 2013 08:50, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Jonathan,
please read my comments inline below…
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Tue, Nov 12, 2013 at 9:27 AM, Jonathan Moules
<jonathanmoules@anonymised.com> wrote:
Hi List,
We’ve recently taken deliver of some aerial photography.
As lossless GeoTIFFs, the RedGreenBlue data is 278GB
As a compressed JP2 file the data is 26GB - the JP2 is almost as good as the
GeoTIFFs and comes with pyramids built in.
Unless you have an ECW or Kakadu license JP2 reading won’t be as fast
as GeoTiff, I mean, nowhere near to it :slight_smile:
But for speed purposes with GeoServer I’ve created an imageMosaic of 13 Jpeg
compressed GeoTIFFs with overviews/tiles etc. This comes out at a massive
106GB and the quality is worse than the JP2 file despite being four times
the size.
Can anyone advise how I can improve these files to make them smaller
(ideally with better quality too)? I created each of the GeoTIFFs with the
following two commands
Merge, tile, and compress all at once.
gdal_merge -q -o file_name.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co
COMPRESS=JPEG -co JPEG_QUALITY=50 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512
–optfile tiff_list.txt
I believe quality is too low. This makes the files smaller but also
makes the jpeg artifacts quite visibile. I would go with the default
which is 75%.
Moreover, you should use this switch PHOTOMETRIC= YCBCR to improve
JPEG compression.
Pyramids
gdaladdo -r average %THIS_DIR%.tif 2 4 8 16 32 64 128 256
This is correct but could be done better. Since the base level is
compressed I would compress overviews as well.
gdaladdo -r cubic -config COMPRESS_OVERVIEW JPEG --config
PHOTOMETRIC_OVERVIEW YCBCR %THIS_DIR%.tif 2 4 8 16 32 64 128 256
This should provide more quality but also relatively small size.
Using JP2 with GDAL is tempting (though supposedly much slower) - but we’re
likely to be putting up four band (RGB + Infrared) data, which I think we
can use GeoServer to visualise (still to play with). JP2 can’t handle four
bands.
Ehm, I am playing with 4 bands JP2 just these days, hence I am not so
sure this is true (which means I believe it is not :slight_smile: )
I am doing some work to improve performance + quality of 16 bits 4
bands imagery, if you move on along the JP2 lines I could make good
use of a sample.
Am I doing something wrong with the GeoTIFF creation?
Thoughts welcome.
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and
register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
