dylan,
What happens when you do this query? Does it give you an error or just
a blank image?
You are using SLD-"HTTP GET" in the SLD-Style Library mode (ie. you have
a SLD_BODY and LAYERS=) . You probably dont want to do that. Get rid
of your "layers=..." from the request (your SLD defines the layers you
want).
Is it generating the correct request URL? There could be a URL
encoding/decoding problem.
If you are hitting geoserver you can add a "&validateSchema=true" and it
will validate your SLD.
dave
This mail sent through IMP: https://webmail.limegroup.com/
