Hi , I'm newbie, and I have to build a mosaic with 4000 files, the steps are Ok until I seed in GWC this mosaic, and these things are happening to me:
1- Build white images,and generates the folders.(fault mine?)
or
2- Build the images, but some tiles are lost, some zooms lost all tiles.(gwc or geoserver fault?)
or
3- None are built, geoserver shows logs " Too many open files". (Tomcat fault?)
How I can solve each one these errors?
Thanks in advance.
"Too many open files" usually refers to a limitation in the operating system, that you actually have too many files open. I doubt it's Tomcat's fault, the question is whether it's a necessity due to the Mosaic or a bug in either the mosaic or gwc.
1 and 2 definitely sound like symptoms of 3, GeoTools tends to quitely render incomplete tiles if the backend fails along the way.
I would like to know
1) Operating System
2) Version og GeoServer (and GeoWebCache, if it's separate)
3) If Linux, output of ulimit -n
4) Does this happen right after you start seeding, or after a long time?
5) Amount of memory and swap in the machine
6) JVM settings?
7) How many seeding threads you were running
-Arne
or
or
Thanks in advance.
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Simone or Daniele: Out of curiosity, any estimate of how many of those 4000 mosaic files would be open simultaneously, per request?
5 to 10 threads is a lot. Try with 1 first, if that works we can look into increasing the limit. But given the amount of memory you have available, and the fact that everything is running on the same machine, I would not run more than 3 threads anyway.
Good thing you're not running Windows, I would have no idea how to check the number of open files or increase it beyond telling you to buy more RAM
-Arne
ps. Please don't forget to CC geoserver-users
1) Operating System
Ubuntu.
2) Version og GeoServer (and GeoWebCache, if it's separate) .
1.7.3, with GWC
1024
Just start..
RAM 3,2 GB and swap 8,7Gb
6) JVM settings?
We have this conf.
"-Xms2560m -Xmx2560m -XX:MaxPermSize=128m"
Between 5 and 10.
1) Operating System
6) JVM settings?
-Arne
or
or
Thanks in advance.
Arne Kepp
