[Geoserver-users] GeoWebCache - How to hide/replace 404 errors for missing tiles
Hello,
I would like to know if there is a setting or a trick to have GeoWebCache send blank tiles instead of a 404 error when a request does not match the area of the data.
I have the option to put a reverse proxy in front of GeoServer to do the trick but I would prefer to avoid adding a new component in my architecture for this requirement.
Alexandre Gacon
Hi Alexandre,
you don’t say which service you’re using (that matters)…
For example, returning 404 is a requirement from the WMTS specification, omitting that would make the server non compliant.
An explicit test for it is mandated as part of the “Abstract Test Suite”:
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Hi Andrea,
We indeed made tests with wmts, through the viewer available in GeoServer.
I will check with other services if we can have a behaviour which is ok with the customer requirements.
Alexandre
Le mar. 4 avr. 2023 à 09:51, Andrea Aime <andrea.aime@anonymised.com> a écrit :
Hi Alexandre,
a) Test purpose: Verify that when a request contains a TileRow or TileCol incorrect, then the server throws an exception.
b) Test method: When a request contains a TileRow or TileCol greater or equal to MatrixHeight and MatrixWidth respectively for the selected TileMatrix, then the server throws an exception (code= TileOutOfRange) in Procedure Oriented Architectural Style or a HTTP 404 File not found in Resource Oriented Architectural Style.
So it’s actually a service exception when using KVP style, and a 404 when using the RESTFul style.
In any case, as far as I know there is no way to change the existing behavior (right or wrong which might be) other than changing the code itself.
We could even have a flag to make the server more lenient for example, as long as it’s clear that could have compliance consequences (if it’s WMTS restulf that we are talking about).
Andera
On Tue, Apr 4, 2023 at 8:33 AM Alexandre Gacon <alexandre.gacon@anonymised.com> wrote:
Hello,
Alexandre Gacon
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
