i am trying for the first time to make a new gridset. I have read the docs, and seen many examples. There are of course many configuration parameters, but I would like to start at the beginning and start the gridset with as few parameters as possible and then gradually build them into the geowebcache.xml file.
system: Ubuntu 10.04/ Geoserver-2.1.2 / Geowebcache -integrated geoserver version
My question is…how can I really test out the gwc configuration to find out whether it works?
yours,
Rob
My first attempt is the following:
create geowebcache.xml in the gwc directory of GEOSERVER_DATA_DIR
( Question!! does the geowebcache.xml have to be owned by tomcat6?..what about file permission?)
Obtain the srs extents from http://www.spatialreference.org…in my case they were for EPSG:31467 and therefore
- Projected Bounds: 3386564.9400, 5237917.9109, 3613579.2251, 6104500.7393
- using this as a a template (source: http://geowebcache.org/docs/1.2.2/_sources/configuration/xml/simple.txt) I created my geowebcache.xml file
1.2.2
120
31467
31467
3386564.9400
5237917.9109
3613579.2251
6104500.7393
256
256
