[Geoserver-users] geowebcahce URL ?
geowebcache is working from the demo page , but its not working when I have followed the instructions and modified the url
http://192.172.2.23:8080/geoserver/gwc/service/wms?bbox=72.95237884975721,33.613647508499554,73.12553929320826,33.76539881952458&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:isb123&width=800&height=657&srs=EPSG:4326
what is wrong with the above url?
regards,
Imran
I.R
It's not a tiled WMS request, unless you've configured the tile dimensions to be 800 by 657.
See [1] for the default settings for EPSG:4326 and EPSG:900913
-Arne
1: http://wiki.osgeo.org/wiki/WMS_Tiling_Client_Recommendation
regards,
Imran
I.R
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
but then how is the gwc/demo working? I opened the same layer from demo page and there it is rendering tiles and showing?
On Mon, Dec 14, 2009 at 12:56 PM, Arne Kepp <ak@anonymised.com> wrote:
It’s not a tiled WMS request, unless you’ve configured the tile dimensions to be 800 by 657.
-Arne
http://192.172.2.23:8080/geoserver/gwc/service/wms?bbox=72.95237884975721,33.613647508499554,73.12553929320826,33.76539881952458&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:isb123&width=800&height=657&srs=EPSG:4326 <http://192.172.2.23:8080/geoserver/gwc/service/wms?bbox=72.95237884975721,33.613647508499554,73.12553929320826,33.76539881952458&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:isb123&width=800&height=657&srs=EPSG:4326>
regards,
Imran
I.R
Arne Kepp
I.R
The automatically generated demo client is configured with the correct settings, i.e. correct bounds, resolutions etc. Firebug is a nice tool for inspecting the requests.
Look at the HTML source code of the demo and use that as the basis for setting up your own OpenLayers application.
-Arne
On Mon, Dec 14, 2009 at 12:56 PM, Arne Kepp <ak@anonymised.com <mailto:ak@anonymised.com>> wrote:
    -Arne
        <http://192.172.2.23:8080/geoserver/gwc/service/wms?bbox=72.95237884975721,33.613647508499554,73.12553929320826,33.76539881952458&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:isb123&width=800&height=657&srs=EPSG:4326&gt;
        <http://192.172.2.23:8080/geoserver/gwc/service/wms?bbox=72.95237884975721,33.613647508499554,73.12553929320826,33.76539881952458&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:isb123&width=800&height=657&srs=EPSG:4326&gt;&gt;
        regards,
        Imran
        -- I.R
    -- Arne Kepp
I.R
Arne Kepp
http://docs.geoserver.org/1.7.x/en/user/geowebcache/using.html
I`m talking about the above url… it says just add /gwc/service/ … there is no sign of other request
-Arne
regards,
Imran
I.R
Arne Kepp
I.R
I.R
Sorry, that documentation contains some wishful thinking.
I believe this works if you set up a minimally defined OpenLayers application, i.e. just tell it you want to use EPSG:4326 and world bounds. That's what we used to do for the GeoServer demo applications. It's no longer true after they got the ability to choose window size and tiled vs not tiled.
I'll file a bug and will delegate or update the docs when I have a chance.
-Arne
I`m talking about the above url.. it says just add /gwc/service/ .. there is no sign of other request
On Mon, Dec 14, 2009 at 1:07 PM, Imran Rajjad <rajjad@anonymised.com <mailto:rajjad@anonymised.com>> wrote:
        -Arne
            the url
            regards,
            Imran
            -- I.R
        -- Arne Kepp
    -- I.R
I.R
Arne Kepp
alright but can I get a sample url or something so that I can have an idea about what to do at client end?
I believe this works if you set up a minimally defined OpenLayers application, i.e. just tell it you want to use EPSG:4326 and world bounds. That’s what we used to do for the GeoServer demo applications. It’s no longer true after they got the ability to choose window size and tiled vs not tiled.
I’ll file a bug and will delegate or update the docs when I have a chance.
-Arne
On Mon, Dec 14, 2009 at 1:07 PM, Imran Rajjad <rajjad@anonymised.com mailto:[rajjad@anonymised.com](mailto:rajjad@anonymised.com)> wrote:
-Arne
the url
<http://192.172.2.23:8080/geoserver/gwc/service/wms?bbox=72.95237884975721,33.613647508499554,73.12553929320826,33.76539881952458&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:isb123&width=800&height=657&srs=EPSG:4326>>
regards,
Imran
– I.R
– Arne Kepp
– I.R
I.R
Arne Kepp
I.R
If you do not want to use Firebug you can right click on any tile in a GWC demo and select "View image". Every URL is a sample.
You should probably study the OpenLayers API docs and examples to get a grasp of how tiling works. Sorry, can't spend more time helping you with this.
-Arne
On Mon, Dec 14, 2009 at 1:27 PM, Arne Kepp <ak@anonymised.com <mailto:ak@anonymised.com>> wrote:
    chance.
    -Arne
        layer from
        EPSG:900913
               -Arne
               1:
        modified
                   the url
        <http://192.172.2.23:8080/geoserver/gwc/service/wms?bbox=72.95237884975721,33.613647508499554,73.12553929320826,33.76539881952458&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=topp:isb123&width=800&height=657&srs=EPSG:4326&gt;&gt;&gt;
                   regards,
                   Imran
                   -- I.R
               -- Arne Kepp
           -- I.R
        -- I.R
    -- Arne Kepp
I.R
Arne Kepp
