The whole chapter is
"A WMS must support at least one CRS, and maps from multiple servers may be overlaid only if all the selected
servers have at least one CRS in common. This International Standard does not mandate support for any
particular Layer CRS(s). Instead, it only defines how CRSs are identified and discusses several optional Layer
CRSs, in this clause and in Annex B. Map providers may support the CRSs that are most useful and appropriate
to their geographic locale or information community. To maximize interoperability among servers, providers
should also support geographic coordinates by geocentric coordinate systems such as “CRS:84” (see 6.7.3.2),
“EPSG:4326” (see 6.7.3.3) or other ITRF-based systems."
Clearly not mandatory.
-Jukka Rahkonen-
Andrea Aime wrote:
On Thu, Apr 11, 2013 at 4:54 PM, Jonathan Moules <jonathanmoules@anonymised.com<mailto:jonathanmoules@anonymised.com>> wrote:
I've had similar feelings in the past; ArcGIS defaults to CRS:84 if its there, ignoring whatever you specified or the native one is.
I'm not sure if its possible, but the WMS spec says:
So depending on what "should" means, it may be hard-coded. Hopefully someone knowledgeable about the implementation will chip in.
It's definitely hard coded, and I have the feeling it's actually mandatory to pass the WMS compliance tests (but I haven't checked)
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it/> for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
