If i have a getCapabilitiesRequest filtered on a namespace:
localhost:8080/geoserver/geoserver/myworkspace/wms?service=wms&version=1.1.1&request=GetCapabilities
Then it retrieves all the layer of the workspace OK
but also return all the group layers of the geoserver (that belong to no workspace).
How could i set my getcapabilities request so that those group layers are not returned ?
Thanks
Florent Gravin
Camptocamp - Chambéry
0479444492
On Wed, Apr 24, 2013 at 1:55 PM, Florent Gravin
<florent.gravin@anonymised.com> wrote:
workspace).
not returned ?
I don't think you can. That's weird however, are those layer groups
made exclusively
of layers that are contained in myworkspace?
Otherwise they should not be visible...
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Tue, May 7, 2013 at 3:26 PM, Florent Gravin <
made exclusively
No,
some layers of the layer group are not contained in the workspace i used
to filter my capabilities document.
i found a past issue :
http://jira.codehaus.org/browse/GEOS-4849
Couldn't there a problem with the used filtering method ?
Maybe the layer group is returned because at least ONE of the layer of the
layer group is contained by the workspace ?
Oh, right right, that's how it works now, a layer group is returned if at
least one of the layers is visible in the current
context
Ing. Andrea Aime
@geowolf
Technical Lead
Can we change that ?
Actually i think we had a bug there cause ALL layer groups were returned in a filtered capabilities.
To avoid that, we added workspace to layer groups, but we realised we cannot set a workspace to layer groups that contain layers from different workspaces …
So we are stuck with layer groups that contain layers from several workspaces, we can’t set them a workspace, and they appear in all capabilities filtered by workspace.
Any suggestion ?
On Tue, May 7, 2013 at 3:37 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, May 7, 2013 at 3:26 PM, Florent Gravin <florent.gravin@anonymised.com> wrote:
Florent Gravin
0479444492
Oh, right right, that’s how it works now, a layer group is returned if at least one of the layers is visible in the current
context
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
I don’t think you can. That’s weird however, are those layer groups
made exclusively
No,
some layers of the layer group are not contained in the workspace i used to filter my capabilities document.
Couldn’t there a problem with the used filtering method ?
Maybe the layer group is returned because at least ONE of the layer of the layer group is contained by the workspace ?
On Fri, May 17, 2013 at 11:02 AM, Florent Gravin <
workspaces ..
workspaces, we can't set them a workspace, and they appear in all
Any suggestion ?
Someone has to go and change the code, and update the tests.
However there is a catch... what if someone else actually wants the
behavior like it is today?
Do we need some flag to reinstate the old WMS 1.1 behavior somewhere (even
if it's just a system variable?)
Ing. Andrea Aime
@geowolf
Technical Lead
Ok we will do a PR about that…
Just adding combo params into workspace or global configuration to ask if we want :
- all layer groups
- no layer groups
- layer groups if at least one layer group belong to the workspace
- layer groups if all layer of the layer group belong to the workspace
on a filtered by workspace getcapabilities request.
cheers
On Fri, May 17, 2013 at 11:17 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, May 17, 2013 at 11:02 AM, Florent Gravin <florent.gravin@anonymised.com> wrote:
Florent Gravin
0479444492
Any suggestion ?
However there is a catch… what if someone else actually wants the behavior like it is today?
Do we need some flag to reinstate the old WMS 1.1 behavior somewhere (even if it’s just a system variable?)
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, May 22, 2013 at 2:48 PM, Florent Gravin <
Ok we will do a PR about that..
we want :
- all layer groups
- no layer groups
Florent, I'm afraid that if we discuss it here not all core developers will
read the discussion.
Can you start a thread on geoserver-devel?
Hopefully it will make it easier to gather consensus on how to approach the
issue.
Ing. Andrea Aime
@geowolf
Technical Lead
