Geoserver config:
Tomcat 8.5.60
AdoptOpenJDK 1.8.0_275-b01
Geoserver 2.19.2
I have set up a layer in Geoserver to use the Time Dimension. This layer works well when using in an OpenLayers map project. However when I run the getCapabilities command Geoserver throws an error:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>javax.xml.transform.TransformerException: Translator error
Translator error
Error occurred trying to write out metadata for layer: CDM_CRASH_MV
Failed to handle time attribute for layer
Problem visiting CDM_CRASH_MV visiting CDM_CRASH_MV.fid–5032e677_17c6d72938d_-30d:java.lang.NullPointerException
Details:
org.geoserver.platform.ServiceException: javax.xml.transform.TransformerException: Translator error
at org.geoserver.wms.capabilities.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:106)
at org.geoserver.config.CapabilitiesCacheHeadersCallback$RevalidateTagResponse.write(CapabilitiesCacheHeadersCallback.java:134)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:1029)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:269)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:52)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:626)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:364)
at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:170)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:215)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:101)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:690)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:616)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1634)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:122)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:100)
at org.geoserver.wms.capabilities.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:104)
… 103 more
Caused by: org.geoserver.platform.ServiceException: Error occurred trying to write out metadata for layer: CDM_CRASH_MV
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayerTree(GetCapabilitiesTransformer.java:959)
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayers(GetCapabilitiesTransformer.java:721)
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleCapability(GetCapabilitiesTransformer.java:480)
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.encode(GetCapabilitiesTransformer.java:334)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:990)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:485)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:283)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:118)
… 105 more
Caused by: java.lang.RuntimeException: Failed to handle time attribute for layer
at org.geoserver.wms.capabilities.DimensionHelper.handleVectorLayerDimensions(DimensionHelper.java:119)
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayer(GetCapabilitiesTransformer.java:1040)
at org.geoserver.wms.capabilities.GetCapabilitiesTransformer$CapabilitiesTranslator.handleLayerTree(GetCapabilitiesTransformer.java:946)
… 112 more
Caused by: java.io.IOException: Problem visiting CDM_CRASH_MV visiting CDM_CRASH_MV.fid–5032e677_17c6d72938d_-30d:java.lang.NullPointerException
at org.geotools.data.store.ContentFeatureSource.accepts(ContentFeatureSource.java:800)
at org.geotools.data.store.ContentFeatureCollection.accepts(ContentFeatureCollection.java:124)
at org.geoserver.wms.WMS.getFeatureTypeTimes(WMS.java:1331)
at org.geoserver.wms.capabilities.DimensionHelper.handleTimeDimensionVector(DimensionHelper.java:712)
at org.geoserver.wms.capabilities.DimensionHelper.handleVectorLayerDimensions(DimensionHelper.java:117)
… 114 more
Caused by: java.lang.NullPointerException
at java.sql.Timestamp.compareTo(Timestamp.java:515)
at java.sql.Timestamp.compareTo(Timestamp.java:72)
at org.geotools.feature.visitor.MinVisitor.visit(MinVisitor.java:94)
at org.geotools.data.store.ContentFeatureSource.accepts(ContentFeatureSource.java:791)
… 118 more
This is causing a problem when trying to add these layers, as WMS, into ArcGIS.
Any ideas on what to do to fix this?
Graham Humphries | System Analyst
ICT & SSG Branch | Department of State Growth
4 Salamanca Place | GPO Box 536, Hobart TAS 7001
P (03) 6166 3155
